C5 shock install--really need special tools?
Old Apr 2, 2011 | 11:20 AM
sothpaw2's Avatar
sothpaw2
Default C5 shock install--really need special tools?
Greetings!
I want to install some new Bilsteins. The car is a C5Z but I suspect all C5s are basically the same in this regard. The shop manual says I need a special tool to keep the spring compressed so that it can be pulled out... but when I went to Pep Boys looking for such a tool (something universal like a big c-clamp or shock compressor), the shop guy said you don't need that.
So can I just jack up the control arm, thereby compressing the shock, then pull the bolts and pull it out?
Thanks,
Andy
Old Apr 2, 2011 | 11:39 AM
bumble-z's Avatar
bumble-z
Correct. No special tools.
Good luck & have your car blocked safely!
Old Apr 2, 2011 | 11:42 AM
jgarrett's Avatar
jgarrett
Guess it depends on how worn out your shocks are I was able to compress mine by hand and pull them out.And on the reinstall I placed the shock on the ground and compressed it and then used zip ties to keep it compressed put the shock in place then cut the ties and let it decompress into place.There is a write up on here somewhere with pics.
Old Apr 2, 2011 | 01:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just used some coat hanger wire, Compress by hand, wrap a loop around the shock, installed them and cut the wire. BAM, DONE!
BC
Old Apr 2, 2011 | 03:50 PM
bsalie99's Avatar
bsalie99
the special tool is on ebay, and it is just a peice of wire that keeps the shock compressed, no need to buy it
Old Apr 2, 2011 | 07:29 PM
12png's Avatar
12png
Originally Posted by sothpaw2
Greetings!
Thanks,
Andy
Cut the dust shield, than cut shock shaft. Do this after you have removed the nut(you can use vise grips on the shock shaft.
Old Apr 2, 2011 | 08:39 PM
baxsom's Avatar
baxsom
Just changed my C5 shocks to C6 ones.
wrenches, jacks, zip ties to hold the shocks compressed.
thats all it takes.
you can compress the shock yourself by putting your body weight on it
Old Apr 2, 2011 | 08:52 PM
Paul 75 L82's Avatar
Paul 75 L82
I installed the C6 Z06 shocks on my C5 Z06 today. Do a Google search on McRat Shock Install. It's a very good write up. Took me 6 hours without a lift and with a lunch break. Good Luck.
Old Apr 2, 2011 | 10:40 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
zip ties here too. be careful around the cv boot. if you don't, you'll get to learn how to rebuild one too
Old Apr 2, 2011 | 11:00 PM
sothpaw2's Avatar
sothpaw2
Zip ties worked but had to re-jack up a few times to get the shock fully compressed to get it off. PIA.
But...I started another thread...can someone post a pic of the clevis end of the front bilstein sport??? Mine is flat with respect to the body...the OE's are at an angle. The angle seems entirely necessary to get the bottom 2 bolts to the control arm in place and get the shock at the right angle.
I don't know how the B sport is supposed to go into anything unless it's a car with the shocks pointing straight up. The corvette shock is at a substantial angle from the CA to the shock tower at the top.
Old Apr 2, 2011 | 11:01 PM
KorbenDallas's Avatar
KorbenDallas
This is how I did mine. I tried the loom and it was a PIA; zip ties saved the day and made the job easy.
Old Apr 3, 2011 | 02:51 AM
Armycop's Avatar
Armycop
Were mine worn that bad then? I lifted the car (01 coupe with 3yrs of HPDE's), hanging the suspension, and just unbolted them and compressed them by hand to remove. Sure, there was some resistance initially, but once they got moving it got easier. Am I missing something here? Replaced with coilover's, and I had to clamp the damn thing's to get them compressed. Hm..
Old Apr 3, 2011 | 09:01 AM
rws.1's Avatar
rws.1
There are a couple DIY's on the forum... but the above respondents have told the secrets.... use zip ties on the old compressed shocks to get them out.... yes you can jack the control arm to compress....
Use body weight to compress the new shocks and zip ties to keep them compressed until installed.
Old Apr 3, 2011 | 09:40 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
The only thing you really need beyond the zip ties or wire is a good torque wrench. Adhere closely to the specs in the manual for all bolts. I managed to snap two of the front lower bolts tightening them by hand w/o a torque wrench. I guess I felt those bolts should be a bit tighter than the GM engineers did.
Old Apr 4, 2011 | 02:09 AM
Last C5's Avatar
Last C5
Just put a Cresent wrench on one end of the clevis and turn it to any angle you like. It's just mounted in rubber.
Old Apr 4, 2011 | 12:01 PM
bighank's Avatar
bighank
Default McRat method zip ties and 2 24 MM sockets
No need to cut anything. Rears are a snap. Do need 2 24MM sockets. Got them at H F very inexpensive. Use 2 jacks. Rear need to very slightly remove tension on to remove bottom bolt. On front need to use jack to compress shock then zip tie it.
Look for McRat method which has pics on how to do it.
To C5 shock install--really need special tools?
