Cleaning grounds question.
Old Apr 2, 2011 | 04:54 PM
jeff49's Avatar
jeff49
Default Cleaning grounds question.
Do I have to dissconnect negative battery terminal while cleaning grounds? im in the process of trouble shooting EBCM code c1214H. Does the battery need to be disconnected to remove EBCM. Thanks for all you help on this forum. Jeff49
Old Apr 2, 2011 | 06:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes it should!! Saves arcs and sparks and components!
Old Apr 2, 2011 | 06:23 PM
imavettegirl's Avatar
imavettegirl
i think the rule is anytime you are playing around with any part of a vehicles electronic system you should remove the neg battery cable.
Old Apr 2, 2011 | 06:31 PM
jeff49's Avatar
jeff49
Thank you very much
olbear1962's Avatar
olbear1962
100%
jeff49's Avatar
jeff49
Thank you for your advise
To Cleaning grounds question.
