Should stock C5 automatic fishtail when hitting second and third gears?
Old Apr 3, 2011 | 08:31 AM
mtdoragary's Avatar
mtdoragary
From: eustis FL Saved and blessed; what else matter?
Default Should stock C5 automatic fishtail when hitting second and third gears?
The used C5 I bought for my wife continues to surprise me. the acceleration ability rivals my 375 fuelie powered MG-TF. I wish there were an easy way to tell if their have been internal engine mods!
The only external mods I can see are Corsa exhaust and dual K&N filter setup. The shifts are a lot crisper than I've ever had with a GM automatic as well.
Old Apr 3, 2011 | 08:47 AM
bumble-z's Avatar
bumble-z
No for a stock automatic corvette this is not normal unless on ice.
Buy new tires, before your car kills you & your wife.
Tires may look decent & new but they loose their grip, when old.
Check the "born on" date of the tires.
Be carefull untill then.
Old Apr 3, 2011 | 08:55 AM
rws.1's Avatar
rws.1
My wife's '04 does the same.... but it has 410 gears.....
The crisp shifts sound like it has been tuned....
Old Apr 3, 2011 | 09:44 AM
PTBradford's Avatar
PTBradford
New tires make a big difference. It will still pull causing a big grin to appear on your face, but it will do it without scaring the sh*t out of you.
Old Apr 3, 2011 | 11:09 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Im thinking the same... A computer tune will really wake up the Auto's shift points.
Toque
Old Apr 3, 2011 | 12:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the age of your tires. If ther OLD, get some NEW SKINS.
BC
Old Apr 3, 2011 | 01:21 PM
00Corvette's Avatar
00Corvette
Either way, you should not be chirping or even close to chirping 3rd gear unless the road is wet/icy.
Old Apr 3, 2011 | 03:51 PM
mtdoragary's Avatar
mtdoragary
Road is dry. Tires are good. Does a lot more than chirp.
Old Apr 3, 2011 | 03:54 PM
dmaleck's Avatar
dmaleck
What are the casting # on heads?
Old Apr 3, 2011 | 04:00 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Mine did for a long time - but when I got it 4 Wheel aligned it was a huge difference
May have that checked!
Thanks,Matt
Old Apr 3, 2011 | 04:08 PM
madmatt9471
That is not necessarily true - perhaps he has 3.15 gears and a handheld tuner was used to firm up the shifts etc?
Yes this can happen - did the previous owner ever do anything to the Vette that you know of -
It really sounds like either a street tune was done on it or even a Handheld tuner - which can and will really change the whole feel of the A4, seriously firms and hardens the shifts as well as the RPM and MPH at which it shifts thus equaling the sideways fun
Do you know if you have the 3.15 gears? (G90 & G92 Code located in the glove box) - these coupled with a handheld tuner or street tune done by a shop will do it for you (even with 2.73's)
Thanks,Matt 661-406-7516
Old Apr 3, 2011 | 04:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
So,, I would say you seem to have some HP Mods and a good tune. I would be happy!!
Old Apr 3, 2011 | 04:37 PM
bumble-z's Avatar
bumble-z
Still no mention of date of tires or make/sizes.
Old Apr 3, 2011 | 06:04 PM
mtdoragary's Avatar
mtdoragary
Without pulling any covers I spotted large printed letters "ZB" and a barcode beneath them on the front end of the driver's side head. Then I left for church.
Old Apr 3, 2011 | 06:20 PM
mtdoragary's Avatar
mtdoragary
BC
Michellin ZP's. Mar 07 My tire guy who's been in the business for 40 years says they are in good shape and the rubber is still soft. The car was always garaged.
Old Apr 3, 2011 | 06:21 PM
mtdoragary's Avatar
mtdoragary
I'm happy, but curious. I'd like to know what I've got, but it's not killing me...
Old Apr 3, 2011 | 06:26 PM
mtdoragary's Avatar
mtdoragary
The shifts are seriously firm and hard. The fishtailing comes with traction control ON I don't want to burn up the tires by spinning one wheel! It's got the G90 and G92 codes. It has Corsa exhaust and a carbon fiber over-the-radiator duct and dual K&N cones in front. That's all I can find. Can't get in touch with previous owners. The 3.15 gears likely explains why I get only 30-21 mpg.
To Should stock C5 automatic fishtail when hitting second and third gears?
Old Apr 3, 2011 | 06:57 PM
mtdoragary's Avatar
mtdoragary
My build codes are:
AAB, FE3, NF2, VM3, AG2, FE9, NK4, V49, AK5, G90, N37, V73, AQ9, G92, QF5, XGG, BGR, IL3, T82, YGH, B34, JL4, T96, Z51, B84, JL9, UN0, ISA, CJ2, K63, UY6, IIU, C05, LS1, UZ6, I91, DL5, MXQ, U52, I93, DL8, M30, U75, 41T
At the bottom of the decal were:
BC/CC U382E
Old Apr 3, 2011 | 07:18 PM
dmaleck's Avatar
dmaleck
The casting # wont be on the white tag they will be stamped onto the head, usually on the corner closest to front of car on passenger side of head probably will be 241. I'm just wondering because IF someone were to do internal mods I would think they would atleast upgrade the heads to a 243 or better. I suppose not everyone will do this though.
Old Apr 3, 2011 | 08:07 PM
00Corvette's Avatar
00Corvette
Okay, if you say so. I doubt 3.15 gears allow tire spin from 2nd to 3rd...at WOT you'd be around what 80-85 mph?? I'm a 2.73 car with mods in sig..COW tune..still won't even bark second but for maybe a millisecond. Bald tires or not.
The op is saying this isn't even a "chirp" that the car is actually spinning..I'd like to see a stock C5 spin going into 3rd on dry pavement. not calling BS just saying I'd like to see it on a STOCK car.
Car is modified and/or tuned.
Does your car lope at all? Any possibility of a high stall converter??
It shouldn't be spinning too severely with the traction control on either just so you're aware. Should spin for a brief second then cut power back to gain traction.
