Keeps running
Old Apr 5, 2011 | 01:49 AM
dglad's Avatar
dglad
Default Keeps running
Have a 2000 vette this just started where after inshut it off it will keep running what would cause this? It doesn't do it all the time but once in s while thanks.
Old Apr 5, 2011 | 02:09 AM
DeeGee's Avatar
DeeGee
Smarter engine guys than me will comment
Not a problem I've seen for many years but the usual candidates for engine run on are:
Using low octane gas (but we have a knock sensor to compensate)
sticking throttle idle allowing the engine to idle too fast
badly adjusted timing
A bad thermostat allowing the engine to run hot
Old Apr 5, 2011 | 02:29 AM
dglad's Avatar
dglad
Thx for the reply as far as I can tell it's not running hot at least by the Gage it idles at about 4-500 rpm's and I have been using 93 octane gas.
Old Apr 5, 2011 | 05:23 AM
ZZ06's Avatar
ZZ06
if its a manual just pop the clutch w/o the throttle
Old Apr 5, 2011 | 05:53 AM
dougbfresh's Avatar
dougbfresh
Doesn't sound like run-on, sounds like a faulty ignition switch.
Old Apr 5, 2011 | 07:55 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree...if its running normally then the ignition switch is suspect. Pull your codes too.
Old Apr 5, 2011 | 09:04 AM
dglad's Avatar
dglad
There are no codes just once in a while after I turn the key off it will run for 1-2 seconds.
Old Apr 5, 2011 | 10:21 AM
ClockworkC5's Avatar
ClockworkC5
same thing happened in my old trans am and it was the spark plugs were leaking. i replaced them and the problem stopped
Old Apr 5, 2011 | 11:39 AM
Cratecruncher's Avatar
Cratecruncher
I'm still not clear whether the OP's car is dieseling after the ignition switch is off or the car is idling normally after ignition switch is in off position.
Dieseling sounds like a very lumpy choking, coughing, pinging idle. It could never be described as a normal idle.
Old Apr 5, 2011 | 01:18 PM
DeeGee's Avatar
DeeGee
I bet this in one of those that would be obvious if we could hear the "overrun"
Old Apr 5, 2011 | 01:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The only thing that initiates engine shut down is the ignition switch. Sounds like one of the contacts inside the switch is burnt and sticking closed.
Recommend ignition switch maintenance. Check out this link:
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Apr 5, 2011 | 04:08 PM
Chicago1's Avatar
Chicago1
Did you get it tuned recently? So your diesling?
Old Apr 5, 2011 | 05:27 PM
dglad's Avatar
dglad
It's not really dieseling. Just after I turn the ignition off it will still run like I never shut it off for like 1-2 seconds.
Old Apr 5, 2011 | 05:31 PM
dglad's Avatar
dglad
I'm trying different gas station also to see if the gas may be the problem.
Old Apr 5, 2011 | 07:24 PM
PEERPSI's Avatar
PEERPSI
Engine run on is very unlikely in a fuel injected car. With carburetors it was possible because there was fuel in the bowl for the venturi effect to draw and the fuel pump was mechanical. If you had some source of ignition it could keep going. With fuel injection once the ignition is cut there is no more fuel even if a hot part was able to ignite it.
I agree with ignition switch servicing or replacement.
To Keeps running
