Cant Check Codes, Need Help
Old Apr 7, 2011 | 11:15 PM
nobreaks254's Avatar
nobreaks254
Default Cant Check Codes, Need Help
Let me just say this is my first Corvette so please excuse me.
Anyway, last nite the service traction control, service abs, and service active handling (or something like that) displayed. With the ignition on, I held options down and press fuel 4 times and nothing happened. What am I doing wrong?
Old Apr 7, 2011 | 11:25 PM
nobreaks254
thats what I did and I got nothing. Can try again tomorrow.
Old Apr 8, 2011 | 04:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you press each button seperately, do they do what they were designed to do?
If the answer is YES, try to DISCONNECT the battery for 10-15 min. Reconnect it (Make sure that you clean the terminals and torque the terminals to 11 FT/LBS) See if that gets you anywhere. Its fixed stuborn IPS and BCM issue on other peoples C5 & C6.
Old Apr 8, 2011 | 06:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Sometimes its in how you hit the fuel button. I had a friend who couldn't get the diagnostics to display. After he tried several times I got in the car and got them to display the first time I tried.
Try again and make sure you are depressing and holding the options button and not letting up on it a little bit. Then make sure you fully depress the fuel button 4 times.
Bill
Old Apr 8, 2011 | 07:18 PM
Z06X's Avatar
Z06X
Also, if your door is open and it is displaying "door ajar" hit reset and it'll clear to the normal display. Then just hold options and hit fuel 4 times one after the other and it'll come up.
Old Apr 8, 2011 | 09:02 PM
Outlawwed Z06's Avatar
Outlawwed Z06
Originally Posted by 8VETTE7
Here are the first 4 steps:
[COLOR="Blue"]The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
you should be able to do it with the engin running. I clear that stupid emmisions o2 sensor code all the time wile going down the road.
Old Apr 8, 2011 | 10:41 PM
nobreaks254
didnt get a chance to play with it tonite. When I push reset, should the display clear? I hear a clicking sound when reset is pressed but the display does not clear.
Old Apr 9, 2011 | 06:42 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
All messages must be acknowledged first or else I don't think it'll work....door open and etc...push and hold the options button then touch the fuel button 4 or 5 times within 5 seconds or so.
Old Apr 9, 2011 | 12:10 PM
Outlawwed Z06
hold the reset buton untill it clears.
Old Apr 9, 2011 | 06:59 PM
madmailman96's Avatar
madmailman96
Got the same problem no matter how many times i clear it, it keeps coming back immediatley.
Old Apr 9, 2011 | 07:16 PM
madmailman96
C1214 h c is the code you probably have just found out i have to get my ebcm sent out to get repaired.
Old Apr 10, 2011 | 03:56 PM
nobreaks254
Ok I finally got it. Thanks guys. The codes I got are b1542h, u1160h, b2265h and c1214hc.
Old Apr 10, 2011 | 04:48 PM
madmailman96
That stinks, your ebcm is done,get it taken off and send it to absfixer.com, the dealership will try to charge you $1500 + labor to get a new one.
Old Apr 10, 2011 | 05:41 PM
dgrant3830's Avatar
dgrant3830
B1542 Oil Temperature Circuit Short to GND
U1160 Loss of Communications with LDCM
B2265 Horizontal Position Sensor Fault
C1214 Sol Valve Relay Contact or Coil CKT Open
To Cant Check Codes, Need Help
