HVAC fan not working
Had a dead battery this morning, which I just now (evening) determined is most likely due to my changing the setting for the dash lights to always be on, while I was playing with some new features of the car.
So the jacktard who jumped me ended up crossing the polarity on my battery, which seems to have caused some issues.
First - the radio and HVAC fan were dead. I found the fuse for the radio which was indeed blown, and once replaced we had radio again.
This afternoon, the car was dead again, I replaced the battery with a brand new one, and even now the HVAC has no fan. The unit in the dash seems to work correctly, meaning the lights are on, and the indicator for the fan levels change etc, but no actual air moves. I tried pulling every fuse I could find that might have something to do with the HVAC, and they were all good.
The only codes the car is throwing related to the tire pressure sensors - the HVAC shows no codes.
Any ideas on where to look next?
On the positive note, I took my first on ramp to a freeway in the car today.
Thanks in advance
Thanks for the information you were able to provide w/o model info.
Cheers
Kirk
The complete module is located on the underside of the HVAC Air Plenum in the passengers foot well:
The rear screw plate is SLOTTED, so just loosen them
Heres the inside of the module:
Here is what usually fails. See the burnt foil trace:
I love this forum - it has been a great resource for me - I hope to be able to pay it forward as I learn more about these great cars!
