Shock replacement parts?
Old Apr 12, 2011 | 08:36 PM
mickey_7106's Avatar
mickey_7106
Default Shock replacement parts?
Getting ready to replace my Z51 shocks with some KONI Sports (3013 1023 & 3013 1024) that i bought from a forum member for a killer deal! the shocks are missing parts as you can see in the pics below. im sure most of the parts transfer over but what exactly do i need to make this a complete replacement?
this looks like what i need after searching for a bit? will the parts already on my car be the same?
Old Apr 12, 2011 | 08:40 PM
mickey_7106
also does anybody have installation instructions for these particular shocks?
Chip mention that i need to cut the bump stop in half since im lowered. can someone please point out which one that is?
Old Apr 13, 2011 | 02:59 PM
mickey_7106
Old Apr 14, 2011 | 02:55 PM
mickey_7106
65 views and nobody has any info or advice?
Old Apr 15, 2011 | 08:40 PM
mickey_7106
Old Apr 15, 2011 | 09:12 PM
lionelhutz's Avatar
lionelhutz
The top shock bushings bushings should be reusable. You will need 2 more of the cupped washers but they can be pulled off the old rear shocks. You will install with cupped washer up, bushing, frame, bushing, cupped washer facing down and nut.
You don't want the cups that cover the shaft otherise they will be facing up and fill with water or road debris.
The bump stops are those bushings that are on the shafts of the shocks.
Peter
Old Apr 21, 2011 | 06:32 PM
autoxer6's Avatar
autoxer6
I installed the Koni 3013 a few years ago. Dont cut the bump stops, and like Peter said, dont use the cups. Use which ever bushings and washers look like they are in the best shape. You may need to drill out the stock washers if you want to use them since the Koni pin top is a larger diameter.
To Shock replacement parts?
