diff help
Old Apr 13, 2011 | 12:09 PM
nygottwins's Avatar
nygottwins
Default diff help
hey guys need a bit of info. I have a 6 speed 2001 vert build 408 ptk twin kit. rear end made a weird noise after taking it apart to replace the clutch decided to pull the rear end apart everything was good at first then I found the cross pin broken. is there a suggestion for a local shop in new york that will put this together for me. do they make a hardened cross pin or should i leave the stock one that seems to be the only factory piece in the rear. any help/info will be appreciated.
Old Apr 13, 2011 | 12:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES,, They make a hardened better pin. DTE Sells it. You can also up-grade to C6 parts.
Im going to provide you TWO FANTASTIC links . They BOTH address hardening the C5 rearend wth better quality C6 parts. I did this toi mine.
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
Just for some knowledge, heres a tranny post also. It's cool to see whats inside:
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
Enjoy!
BC
Old Apr 13, 2011 | 12:58 PM
_r2h's Avatar
_r2h
Enjoy!
BC
Excellent post
Old Apr 13, 2011 | 08:54 PM
nygottwins's Avatar
nygottwins
thanks for the info very helpful. will post pics and outcome in a couple of days.
Old Apr 14, 2011 | 05:43 PM
nygottwins's Avatar
nygottwins
where can i get the hardened pin from DTE. my driveline guy can only get me the stock pin. i don't see any point in doing that. clutch arrives tuesday from mcleod from a complete rebuild. would like to have it up and running friday or saturday next week.
Old Apr 14, 2011 | 06:56 PM
Chris Stewart's Avatar
Chris Stewart
Get the hardened pin for $99 from RPM transmissions. http://www.rpmtransmissions.com/differentialparts.html
That way you don't end up like this:
Old Apr 14, 2011 | 07:50 PM
nygottwins's Avatar
nygottwins
the pin broke exactly the same way. called rpm but was too late will order tomorrow thanks
Old Apr 15, 2011 | 09:10 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Have a good 2000 C5 from 6spd vert diff at low cost if you want a spare $365.00 plus shipping
To diff help
