Smog fail
Old Apr 16, 2011 | 05:13 PM
TOPGUN9's Avatar
TOPGUN9
Default Smog fail
My C5 just failed smog because the battery had been disconnected for the past couple days, and according to the smog shop, the computer didn't have a chance to relearn yet. How many miles do I need on the car before the computer relearns enough to pass smog?
Old Apr 16, 2011 | 05:49 PM
87SAM's Avatar
87SAM
It's not so much the miles but the amount of cycles (open to closed loop cycles), seems like it's around 40.
Old Apr 16, 2011 | 06:12 PM
Bdiddy's Avatar
Bdiddy
I tell most people to drive at least 100 miles, making sure you have a mix of stop and go, and highway.
Old Apr 16, 2011 | 06:58 PM
WKMCD's Avatar
WKMCD
Or - if you have tuning software you can set everything ready and turn off those nasty offending codes..
Old Apr 16, 2011 | 07:20 PM
baxsom's Avatar
baxsom
or do what I did and move to FL where the dont test for that sort of stuff to begin with.
Old Apr 16, 2011 | 10:33 PM
dougbfresh's Avatar
dougbfresh
Just have to deal with those pesky hurricanes and some of the highest homeowners insurance in the land.
Old Apr 17, 2011 | 09:47 PM
baxsom's Avatar
baxsom
I must have picked the right company then cause I only pay 200 a month for 5 cars and the house.
The secret is to get a house built after 02 and not in a flood zone on the space coast mainland. Hurricanes are few and far between.
Old Aug 12, 2014 | 09:13 PM
Rpetvette's Avatar
Rpetvette
President - COB
I just had this happen as well. I drove the car 100 miles to reset everything and according to the tech he said that one of the computers was still not registering but was acceptable by the State of California. I was surprised as well to learn that this was the case by disconnecting the battery. Apparently this is the case on cars from 1996 to current.
Old Aug 12, 2014 | 09:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Anytime you disconnect the battery OR reset ANY of the PCM related DTCs, the PCM Emission Ready Flags go to NOT ready.
Yep,, it takes drive time and drive cycles. Drive it to work and back several times. It will warm up and cool down and thats what makes the drive cycle happen. To get the fuel system flags ready, make sure that you have more than 3/4 tank (BUT NOT FULL)
Most states allow one NOT READY Flag to pass.
If you don't want to go to the emissions to check the readiness, swing by Autozone and they can use their scanner to check the readiness codes/flags
Bill
Old Aug 12, 2014 | 10:01 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Bill
The fuel level needs to be between 20% and 80% for the evap monitor to run. Here in n.j. You can have one monitor not complete and pass, 99 and older two not complete and it will still pass.
Old Aug 13, 2014 | 09:08 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Make sure your fuel tank is under 1/2 full.... (EVAP test)..... and
Toque
3boystoys's Avatar
3boystoys
There's no codes to turn off, his I/M tests haven't run yet, that's why he's not passing. If you clear ANY codes, YOU WILL FAIL because the I/M tests will need to run again.
Be sure to let the tank get below 1/2 so the evap test can run.
To Smog fail
