C5 2004 convertible wiper problems
Old Apr 18, 2011 | 07:47 PM
tony812's Avatar
tony812
Default C5 2004 convertible wiper problems
Hi guys I'm new here and I need your help. Wipers went on and never came back down to stop position. Wiper fuse is burning when I place the ignition key on without even starting the engine. Wiper switch is not on when this happens. I also disconnected the connector to the wiper motor and again the wiper fuse burns out when I turn the ignition key in on position. Has anyone ever had this problem? Your help would be greatly appreciated. Montreal.
Old Apr 18, 2011 | 08:14 PM
lucky131969's Avatar
lucky131969
Try the following. Remove minifuse 10 in the passenger footwell fusebox. Then check the resistance to ground, on the wiper motor plug, pin B, yellow wire.
