C-5 Sway Bars
Old Apr 22, 2011 | 08:19 AM
MR.G.'s Avatar
MR.G.
Default C-5 Sway Bars
I sold my C-6 coupe and recently purchased a 1998 c-5 Vert. I am not totally familiar with it yet. Will the sway bars from a c-6 work on my 98 c-5? What about struts?
Old Apr 22, 2011 | 09:59 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
STRUTS?????????????? No struts on a C5 or C6. They use shocks and tranvers fiberglass springs.
Yes the C5 and C6 shocks are the same. The BEST C6 shock for a C5 are the C6 ZO6 shocks and the C6 sway bars are the c6 Z-51 bars.
BC
Old Apr 22, 2011 | 10:01 AM
lucky131969's Avatar
lucky131969
Yes the sway bars will fit. There are no struts on a C5/6.
Old Apr 22, 2011 | 02:41 PM
melvingregory's Avatar
melvingregory
BC
I agree on the combination, that's what I have on my 98 vert along with C6 Z06 OEM wheels and the handling was noticeably improved.
Old Apr 22, 2011 | 09:49 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Bill is certainly right and we would be happy to help you out with the C6 Z06 shocks and C6 Z51 sway bars.
Old Apr 23, 2011 | 10:17 AM
mophead's Avatar
mophead
I just put this exact upgrade on my 2000 last night. Excellent upgrade. Do the metal links also! My plastic link on the front sway bar passenger side was broken. Took a short ride after finishing last night and the difference is very noticeable.
Thanks Gene!
Old Apr 23, 2011 | 10:19 AM
dankhts's Avatar
dankhts
recently installed C6 Z51 shocks and sways on my '02 vert - simple and straight forward, a world of improvement over stock
Old Apr 23, 2011 | 04:58 PM
bighank's Avatar
bighank
Default Used C5 Z51 bars and C5 Z06 shocks on my 98
I have heard that C6 Z06 shocks and sways might give you a ride that is too stiff. That said if you already have C6 bars use them and see how you like it. In any case ditch the plastic end links and go with metal. What a difference. The shocks seemed to make more difference than the sways. Did it in 2 stages, shocks first.
Old Apr 23, 2011 | 08:27 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Why the C6Z shocks, but not the C6Z swaybars?
Old Apr 23, 2011 | 08:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you have some very wide tires, it isnt as efficient as smallar bars. You will lift a wheel in a turn
Old Apr 23, 2011 | 09:14 PM
mcm95403's Avatar
mcm95403
The C6Z rear bay is WAY stiffer than the front bar due to the preference of the main guy who helped develop the package. For most drivers it's not the best feeling setup, hence the preference for the C6Z51 bars.
Old Apr 23, 2011 | 09:29 PM
c59001's Avatar
c59001
Just put c6z06 sways on this weekend and what a big difference they make. also have Pfadt shocks too. good combo.
To C-5 Sway Bars
