Differential question
Apr 27, 2011 | 04:57 PM
Will a differential from a 2001-2004 fit into a 1997 coupe?
The carrier I am looking at is a 3-rib unit out of a Z06.
Also my car is an automatic. Does this make a difference? (no pun intended)
Apr 27, 2011 | 05:10 PM
Yes it will bolt right up w/no problem.
You will have a seal plate between the trany/diff.
Apr 27, 2011 | 05:13 PM
Excellent!
I started getting really nervous when the first shop I called told me they would have to remove the engine to do it.
Started second-guessing myself.
Apr 27, 2011 | 05:15 PM
Quote:
Originally Posted by
Fuzzmauler
Excellent!
Make sure you dont use them!
Apr 27, 2011 | 05:33 PM
I just called the local dealer and got a quote of $1040 plus fluids for the swap.
That seems a little high to me. He did say that that was the shop labor time and if it went faster it would be cheaper.
I was thinking 600 would be closer to a fair price...
Apr 27, 2011 | 07:16 PM
Check around for a shop that specializes in C/5 , C/6 Corvettes in your area.
I'd stay away from dealer shops.
Apr 27, 2011 | 07:23 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats way too muh and NO you do NOT need to pull the engine. Someone from down there will chime in and recommend a local shop.
If you want to bullet proof your new unit for a few bucks, heres an interesting and helpful post!
- C5, Its Go Time, Output Shaft Install - Left and Right :
http://forums.corvetteforum.com/c5-t...post1573404441
- C5 RAGTOPWS6, Differential UP-Grade;
http://forums.corvetteforum.com/c5-g...-z06-guts.html
Bill
Apr 28, 2011 | 12:55 PM
Fuzzmauler
Call Geoff @ Next Level Performance 407-869-7223 he will treat you right.
Their located in Altmont Springs not far from you.
Bob
Apr 28, 2011 | 01:07 PM
corvettebob1
Bob
Way to step up, corvettebob1.
I'm a true believer in finding places to do bussiness with by past expereiences & of word of mouth from others.
Apr 28, 2011 | 06:24 PM
corvettebob1
Bob
Awesome recommendation corvettebob1!
Called him and he quoted me a much more reasonable figure.
Looks like I've still got some some spending money left.
Apr 28, 2011 | 06:34 PM
Fuzzmauler
Plus He won't be pulling the motor to change out the rear diff
Apr 28, 2011 | 06:43 PM
Hopefully he saved you so much money that you can now add a mild stall converter.
Apr 28, 2011 | 06:54 PM
Bluefire
Indeed, that is what I was thinking. It would be a shame to do all that work and want to add a stall later...
What would be a good "mild" stall? Keep in mind I only drive my Vette on the street. I may run it down the track at some point but my baby is mostly for driving casually... (my definition of casual may be different than most soccer moms)
