Cam kit install.. please advise!!
Old Apr 28, 2011 | 10:25 PM
Marinevette1's Avatar
Marinevette1
Default Cam kit install.. please advise!!
My mechanic is installing an LG camkit with the whole works, LS6 pump and UD pulley. He doesn't normally do these kind of installs, but he's the only guy I trust to work on my car while away. I've known him my whole life he was my next door neighbor so I know he's not lying to me. He usually doesn't do internal work and was asking me to gather knowledge on the computer. I was under the impression that after the install I would just take it to a local tuner and have them tune the car on a dyno to make it drivable and get the performance gains from the car. He said that might be true but is concerned the stock computer won't be able to be adjusted for the timing curves or various other things I am not very knowledgable about. Can anyone assist with advice. I wouldn't need a new computer or anything like that would I?
For refrence it's a 1999 C5 convertible with a 6spd. Various bolt on mods to include LT's, Vararam and LS6 intake/ ported TB and many more. Low mileage (65k).
Old Apr 29, 2011 | 12:13 AM
jonnyc's Avatar
jonnyc
it's always best to have a set of service manuals.they have all the info you need to do anything on the car.
this is probably the best write up for doing a cam swap.
http://ls1howto.com/index.php?article=1
as far as the computer,a good tuner can adjust whatever is needed to get the car to run like it should.i would go into the "great lakes" section in the regional area. start a post asking for a good tuner in your area.
Old Apr 29, 2011 | 05:05 AM
vettenuts's Avatar
vettenuts
You won't need a new computer but it may not run real well depending on the size of the cam. If he is not familiar with tuning, and you are away, I would suggest he not run the car a lot expecially at higher RPM after the installation is finished until the tune can be checked. Doing so could cause damage depending on how far off the tune is and why risk it.
Old Apr 29, 2011 | 07:47 AM
Paul 75 L82's Avatar
Paul 75 L82
I agree that you don't want to drive the car alot before the tune, but I have been told that the valve springs need 3 heat cycles before you go red line at the tune. With my cam install the battery was disconnected for about 3 weeks and the PCM loss the idle. To correct you have to drive the car some to relearn.
PS: Tell your mechanic to join the forum and we can help him out if he has problems.
Old Apr 29, 2011 | 01:42 PM
zeevette's Avatar
zeevette
Or you can send it to ECS for a mail order tune. That should get it close enough to drive.
Old Apr 29, 2011 | 04:20 PM
Marinevette1
These were my thoughts as well. I did a lot of research on the parts I purchased and always do before I buy anything. I also like to buy quality items. He is an excellent mechanic he just doesn't do this type of internal work. He isn't a tuner or anything of the sort. He is fine doing the install he was just warning me about the computer because he wasn't familiar with this setup. I told him I had a tuner in the near by area with an appointment set up for the actual after install tune. He won't really be driving the car at all. He's going to get it running after the install and my dad will be grabbing the car until I get home and bring the car to the tuner.
To Cam kit install.. please advise!!
