Real quick question on the starter
Old May 8, 2011 | 04:04 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Default Real quick question on the starter
According to this the only black wire should be from the solenoid to the starter.
So there is no wire going to the black terminal and the main 8 gauge ground should be going to the block from the battery? Along with the smaller ground strap down there?
Old May 8, 2011 | 05:27 PM
Z06PSI's Avatar
Z06PSI
O.k. I'll answer my own question. Yes the big black and the small black wire go to the block.
Old May 9, 2011 | 12:39 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Glad you figured it out. That looks right to me.
Old May 9, 2011 | 03:31 PM
Z06PSI's Avatar
Z06PSI
Putting the battery in the back for a larger intercooler reservoir.
To Real quick question on the starter
