PAC valve spring ?
Old May 10, 2011 | 11:10 AM
D&A'sDad's Avatar
D&A'sDad
Default PAC valve spring ?
It is time to refresh the valve springs on my stroker:
I have been advised to stay away from the double springs for my application.
My question is: should I use the PAC 1218's? or would the PAC 1518's be a better choice ?.......fair price? source?
cam specs are: 228/232 .581/.588 114 LSA+4
THANKS
Old May 10, 2011 | 11:15 AM
WKMCD's Avatar
WKMCD
The 1518's are a nitrited spring and will last much longer. I've had my 1521's in for 3 builds and they are still like new even running .660 cams.
Old May 10, 2011 | 11:57 AM
vettenuts's Avatar
vettenuts
For what reason?
Old May 10, 2011 | 12:34 PM
D&A'sDad's Avatar
D&A'sDad
Originally Posted by vettenuts
For what reason?
I myself am not technicaly qaulified to give you the entire anwser but I think that they are in some cases to tight for the valve train.....not spec'd for the valves etc????.... or maybe better said that overkill may not always be the best pratice......not saying doubles are bad but that in some cases they may be to much.....
Sorry that's the best I got!
Old May 11, 2011 | 02:48 AM
ZeeOSix's Avatar
ZeeOSix
... the 1218s and 1518s have the same exact dimensions and specs for spring rate/pressures. The 1518 is nitrited, and because of it, is rated to 0.650" lift instead of 0.600" lift for the 1218. The 1518s can take more abuse.
I'm almost ready to replace the OEM springs in my LS6, and have pretty much decided to go with PAC 1518s. They should be very reliable in a stock LS6.
A thread from a while ago talking about PAC 1518 springs:
http://forums.corvetteforum.com/c5-t...ac-1518-a.html
PAC 1218 Specs:
http://www.racingsprings.com/Store/P...?ProductID=206
PAC 1518 Specs:
http://www.racingsprings.com/Store/P...?ProductID=220
Old May 11, 2011 | 05:10 AM
vettenuts's Avatar
vettenuts
Do you know what springs you are currently running? Reason for asking is that if currently running duals, you will need more than just springs to go to a beehive and vice versa.
Old May 11, 2011 | 08:06 AM
D&A'sDad's Avatar
D&A'sDad
They are whatever AFR uses on 205's. They were refreshed around 25,000 miles ago(by 1st owner) and at the same time the the AFR recall was done on the valves etc.....the gent that had this stroker built and installed at A&A is a very tech savy car guy and is the one whom advised that doubles are safer but are not compliant, so I am sure that it does not have doubles.
Old May 11, 2011 | 11:39 AM
vettenuts's Avatar
vettenuts
I would first find out what you have. You might be able to see the spring under the oil fill with a mirror and flashlight. Second, if they are the AFR springs you are going to need seats, retainers, seals, etc. to get to a beehive setup. I also think if you speak with Tomy Mamo, he will highly recommend you stick with the AFR valve springs.
As for beehives on the AFR's, that may not be a straight forward swap due to valve stem heights, valve weight, etc. I would strongly suggest contacting Tony Mamo to get input before spending any money.
Old May 11, 2011 | 02:01 PM
D&A'sDad's Avatar
D&A'sDad
thanks and I will do that.
Old May 12, 2011 | 04:50 PM
D&A'sDad's Avatar
D&A'sDad
Thanks vettenuts!!! your were right on, I would have needed more than just springs to put beehives on these AFR's......AFR 8019's enroute.......thanks again!!!!!!!
It almost always pays off to bounce questions off the forum
Old May 12, 2011 | 05:50 PM
vettenuts's Avatar
vettenuts
Great
To PAC valve spring ?
