Computer Reflash???
Old May 12, 2011 | 04:19 AM
jdot's Avatar
jdot
Default Computer Reflash???
Read an article last night saying after a few years the C5's computer needs to be "reflashed" to install "updates." Is this true, what's involved and what's the cost and what is "reflashed?" Does it apply to ALL C5's or only stock and who does the reflashing? The more I read about Vettes, the more I feel I needed to enroll in brain surgery school.
Old May 12, 2011 | 06:20 AM
Cybermind's Avatar
Cybermind
Never heard of that. I haven't read anything concerning flash updates for the C5. It would help if you let us know the article that you're referring to or maybe post it up.
Old May 12, 2011 | 06:26 AM
lucky131969's Avatar
lucky131969
This would normally only apply within the confines of the warranty period, or the series run i.e 97-04...to make sure TSB's have been applied, recalls..etc.
Old May 12, 2011 | 07:48 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Some dealers offer flash updates with their servicing. The dealer I use to live near, did this if you wished.
Old May 12, 2011 | 10:49 AM
dgrant3830's Avatar
dgrant3830
Originally Posted by 8VETTE7
And for those with custom tunes don't let the dealer near it unless you want to have to pay for a retune. If the dealer reflashes the PCM your tune is gone......
That is the fact too.... I agree!!! If you have a custom tune, you'll lose it for sure.
Old May 12, 2011 | 01:49 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Reflashes offered by the dealer are just to update your tune IF the factory finds a mistake or to update settings that they have found to be incorrect or a new setting they have found that works better-
Most common in the Duramax's---The dealer will often do a re-flash without your asking for one or without your knowlefge
I would never let them reflash a car with an aftermarket tune--as you will lose the tune--I subcribe to the "don't ask don't tell " policy whrn it comes to a car with a tune--Never volenteer that your car has been tuned--just say it runs good--These days the dealer will look for any reson to not honor your warranty or a somg shop will not pass your car if you say it's tuned just so they can ding you for another $39
ALSO reflashed set ALL your" readiness monitors" to not ready--so if you are in the midst of trying to get it smogged--you will have to drive it apprx 50-75 miles to set the monitors to "ready"
It also deletes all your codes so if you have a problem with the engine the codes will be gone--Make sure you read the codes before a reflah--
Old May 12, 2011 | 04:41 PM
Blow Torch's Avatar
Blow Torch
Old May 12, 2011 | 05:03 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I posted the same question about 2 weeks ago, with only one reply (thanks, "8VETTE7").... There was a "sidebar" that mentioned this, in the current Corvette Central catalog, on the page where they sell BCMs and PCMs.
Old May 12, 2011 | 06:29 PM
C5blownz06's Avatar
C5blownz06
I wouldn't take my car to the dealer for anything,. Those poorly paid oil change monkeys will do it more harm than good.
Old May 13, 2011 | 10:48 AM
rebelheart's Avatar
rebelheart
Basically,if you arent having any issues,you dont need it!
Old May 13, 2011 | 11:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Whenever I would take my 02 ZO6 into the dealer for WARRANTY Work (yes it had a tune) I would ask to examine the warranty work order paperwork and in the remarks block, I would write in LARGE PRINT "DO NOT REFLASH THE PCM"
I never had an issue and they didn’t have an issues honoring the request.
YES,,, a PCM re-flash will completely remove any aftermarket TUNE!
If you have major mods like a CAM, different Injectors and ported heads, your car might not even RUN after the re-flash. Then its going to cost you $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ cause there going to want to replace high dollar stuff to try to get it to run again!!
YES it happens.
BC
Old May 13, 2011 | 09:14 PM
jdot's Avatar
jdot
Found the article while surfing old threads on C5 Technical last night. Article did warn against reflashing if you'd done mods to the engine. Thanks for the quality info again. You guys are the best.
To Computer Reflash???
