Ticking sound from headers
Old May 13, 2011 | 08:48 PM
hermancar's Avatar
hermancar
Default Ticking sound from headers
1999 c5 H/C and header upgrade. Small cam-xr265hr high lift,Pro comp heads assembled locally,(918 springs)Original rockers,New ls7 lifters,7.4 bpush rods. When started it is smooth and quiet woith normal injector sound (New 28.8 injectors). Driving is fine but when motor is hot (not over heated) a ticking sound can be heard fron the header pipes under the car. It is noticible from inside the car. any ideas. Thanks
Old May 13, 2011 | 08:54 PM
Jnape's Avatar
Jnape
did you measure for that 7.4 PR? maybe not enough preload on the lifter/rocker?
Old May 13, 2011 | 09:56 PM
hermancar's Avatar
hermancar
I am using the 7.4 now. I removed one intake and one ex spring and installed checker springs. i manually opened the valve to the lift of my cam (.557) and the print was past center towards the ex side. not a lot.
Old May 14, 2011 | 12:54 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Contraversey going on currently as to using LS7 exh rockers on a LS1
Don't know yet---
But if you are getting some noise beyond the normal sewing machine sound of a LS1--it sounds like an oiling issue when the eng is warm--
What oil and wght are you using ??
also--the ticking will most likely cause fasle knock and pull timing
Old May 14, 2011 | 01:00 PM
MStrahan's Avatar
MStrahan
I just had a terrible ticking and after pulling everything apart it ended up being the air check valves. Tore the system out and no tick.
Old May 14, 2011 | 06:24 PM
vettenuts's Avatar
vettenuts
What kind of headers? I had this issue and used some Torqtite clamps which took care of it. Depends on the kind of headers you have though.
Old May 14, 2011 | 11:09 PM
wfdlt8's Avatar
wfdlt8
Where did you get these clamps from? I don't really care for the clamps that came with my dynatech's and was thinking of getting some new ones.
Old May 15, 2011 | 09:24 AM
Paul 75 L82's Avatar
Paul 75 L82
Exhaust leaks sound like ticking sounds.
To Ticking sound from headers
