i put alot off pressure in each tire and now ever time I turn my car on it beeps high pressure in tires and tells me on the display which ones. i ppress and hold reset and it goes away for time being. how do i fix this. thanks all
Why in the world would you OVER PRESSURIZE your tires??????????? The "NORMAL operating pressure is 28-32 (measured COLD) The optiomal pressure that gives the best ride wear and performance is 30 PSI
Look on the door operating sticker for the factory pressure recommendation.
better gas milege, longer tires life, and more then two shops both told me its okay to run them 2 psi above rating.
does anyone know how to reset the computer screen. thanks
2 psi above which rating? the door or the tires? Check pressure with a tire pressure gauge. You should not be getting any high pressure warnings if its only 32 or 33 lbs in them, sounds like a lot more than 32 psi. And there is no reset to the tire warning message. Take some air out of the tires and measure with a gauge until 30-32, then start it and drive it.
Oh and over inflating the tires will not give them longer life, it just wears the tire center faster than the shoulders shortening the life of the tire because you won't get even wear across the tread pattern. Just keep them properly inflated for gas mileage and even wear.
