Dual climate control
May 21, 2011 | 08:50 AM
I live in Florida and it's about 85 and the temp on the dual climate control says it's 5
May 21, 2011 | 08:51 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
so you are saying the display is not displaying 2 numbers or it is reading in celsius
May 21, 2011 | 08:53 AM
No in celsius it reads -15
May 21, 2011 | 09:00 AM
Quote:
Originally Posted by
pewter99
What no words of wisdom now?
May 21, 2011 | 09:02 AM
Kurnulklink
well I was going to say if it is a case of single digit display you may just have a loose connection...there have been some soldering fixes posted for the HVAC controller here in tech
May 21, 2011 | 09:04 AM
What would make it read the wrong temp?
May 21, 2011 | 09:07 AM
Kurnulklink
is it reading wrong or only displaying the second number I guess is my question...you say it's 85 but showing 5 so does it actually display anything over single digits?
here is a link to fixing the display
http://forums.corvetteforum.com/c5-t...splay-fix.html
I am no expert but a few folks on here have fixed there control units
I had forum member tstar fix mine so if all else fails PM him he can probably offer some suggestions if no one else does.
BTW where in FL are you?
May 21, 2011 | 11:45 AM
You should check your exterior temperature sensor located in front of the rad intake on the passenger side. The connection could of came loose or it could have broken off. There should be a small black peg sticking out about 3/4 of an inch long.
May 21, 2011 | 12:59 PM
Thanks for the help, I put a new sensor on and it works fine. Thanks again
