Official LS1 oil capacity?
Old May 21, 2011 | 12:15 PM
doublec4's Avatar
doublec4
Default Official LS1 oil capacity?
Hey guys, I searched around and have read that guys put 5.5 - 6.5 quarts in for an oil change. I think the owners manual says 5.5 quarts but someone had mentioned its a mistake?
Just a little confused, and was wondering what the official correct number is.
Thanks!
Old May 21, 2011 | 12:55 PM
Last C5's Avatar
Last C5
Both my 2001 and 2004 manuals say 6.5 qts with filter and 6.0 qts without filter. I use 7 qts with filter all the time.
Old May 24, 2011 | 02:59 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by 8VETTE7
As long as I am carefull to get all the old oil out, I can round it out as 7Qts with filter.
+1... Just make sure to lift the rear a little at the end of the draining process to get all of the used oil out...
Old May 24, 2011 | 03:19 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Which owners manual are you looking at?
My 2001 owners manual says it's 6.5 quarts with filter change. (Capacities and Specifications on page 6-75)
Old May 24, 2011 | 03:38 PM
jrose7004's Avatar
jrose7004
Mine takes 6.5 quarts.
Old May 24, 2011 | 06:43 PM
ssrodder's Avatar
ssrodder
Default Do not over fill your oil
Never put too much oil in your system. As a matter of fact, less is better than more. You never want your crank coming in contact with excess oil. It slows the engine down and can cause faoming in your oil. Put in 5 quarts and some into your filter before you install the filter. Start the car and check for leaks and add oil as needed. I repeat, do not over fill.
Old May 24, 2011 | 07:14 PM
03z06eb405's Avatar
03z06eb405
I put it 6.5 start the engine up let it run for a few minutes shut it down and wait until the oil drains back into the oil pan.I check the dipstick and top it off as determined what the dipstick reads
Old May 24, 2011 | 09:39 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default More bad information.....
Less is not better than more, when it comes to your engine. Oil capacity is 6.5 gt and if racing 7 qts is perfectly acceptable.. Oil Life algorithms are based on 6.5 qts. Baselines where changed in 2000 from 10,000 miles to 15000 miles. Baselines are the starting point for oil life percentage at 100 %. At 5 qts. you are 1.5 qts low.... not a good cold start suggestion... true that over filling is a no no... most people who change their own oil know how to remove the oil. Filling the filter is also common knowledge for most oil changers. I would never suggest anyone put 5 qts in their LS1. For me.. I put 6.5 qts and 1/2 pint in the filter. Its what I do with that extra .5 qt, of the 7 qts I use in a oil change.. you can't get a whole pint in the filter but if you did it would be fine.
Old May 25, 2011 | 05:42 AM
vettenuts's Avatar
vettenuts
Every time I change mine I drain for a long time with the rear raised some and remove the filter. I then fill the filter and finish silling the crankcase with a total of 6.5 quarts after which the car is run to check for leaks. Inevitably I end up adding the last 1/2 quart as the dipstick always is down 1/2 quart when I check it later.
Old May 26, 2011 | 01:04 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
the oil pan is so wide unlike the older design that 1/2 qt is not going to raise the oil level that much in the pan.
Guys tracking run a full qt over
Old May 26, 2011 | 12:58 PM
joe Villarreal's Avatar
joe Villarreal
Default oil question
I use 6.5 quarts all the time
Old May 26, 2011 | 01:59 PM
TheBigDog's Avatar
TheBigDog
To Official LS1 oil capacity?
