Dead battery even with cutoff?
Old May 24, 2011 | 03:02 PM
Dr V's Avatar
Dr V
Cruise-In I Veteran
Default Dead battery even with cutoff?
Another dead battery question. I have a cutoff on the battery for my 1998. I cut off the battery (working fine, 1 year old) and left for 3 weeks. Came back, reversed the cutoff, battery dead as a doornail. When I cut it off I checked that the lights did not come on, etc. Any ideas? Please no recommendation for battery tender/trickle charger since I park in a condo with no electrical outlets available. Thanks!
Old May 24, 2011 | 03:43 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If you disconnected the battery and it still went dead, I'm thinking you have a bad battery.
Old May 24, 2011 | 03:45 PM
dougbfresh's Avatar
dougbfresh
Old May 24, 2011 | 05:06 PM
Z06 LUST's Avatar
Z06 LUST
Ha, I did not know it was okay to cut off the batter to stop it draining...
I guess this means you can have a lightweigh battery on a weekend car without a battery tender rigged up all the time?
Does this mean the radio code & time need resetting each time you re-connect it?
Sorry for the dumb question, but I'd rather ask, look dumb and know than not ask and remain ignorant!
And sorry for the hijack!
Old May 24, 2011 | 06:22 PM
dgrant3830's Avatar
dgrant3830
Any time the battery is disconnected, things will have to be fixed such as the clock, radio and so on.
Old May 24, 2011 | 07:12 PM
dougbfresh's Avatar
dougbfresh
Not entirely true, many GM radios will keep radio stations for a while after DC is disconnected, If the Security Code was set, that will have to be entered (or cleared).
Old May 24, 2011 | 07:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When a battery is sulfated,the plates inside warp sometimes short out or the sulfate will cause it to short. That causes an internal drain that will happen even if its disconnected. What battery and how old?
03z06eb405's Avatar
03z06eb405
You might have a bad battery. Take it back to where you purchased it and have them check it out.
Old May 24, 2011 | 07:22 PM
dgrant3830's Avatar
dgrant3830
Bill, he said it was only 1 year old
Old May 25, 2011 | 09:06 AM
Carcass's Avatar
Carcass
If the battery went dead in a week with absolutely no load on it,it's a bad battery.
Or a bad disconnect,and the battery's fine-did you check the actual battery voltage?
To Dead battery even with cutoff?
