Key problem --- any ideas?
Old May 28, 2011 | 11:37 PM
T-TOP TOM's Avatar
T-TOP TOM
Default Key problem --- any ideas?
:confus ed2:My 2001 wouldn't start this week untill my wife brought the second set of keys over to me. After getting home I tried the key that didn't work earlier that day and it started two times then wouldn't work again. I took key in to have it checked and the chip showed ok on the key machine compared to the one that works. I measured the thickness of the chip on both keys and the thickness on the one that doesn't work is .008" (eight thousands) thinner than the key that works. Could that be what is causing it not to work? Any ideas if that is the problem?
Old May 29, 2011 | 04:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GOOD INFO!! If you pull the DTCs when the issue happens, it will let you pin point the cause of the issue.
BC
Old May 29, 2011 | 01:34 PM
T-TOP TOM's Avatar
T-TOP TOM
Yes, GTEAT information. I will try that and see what happens. Thanks for reply.
Old May 29, 2011 | 01:36 PM
1986coupe's Avatar
1986coupe
Had the same problem once on my 1986. Got a new key cut and the problem hasn't returned.
To Key problem --- any ideas?
