now what ... cam sensor not working ?
Old May 29, 2011 | 10:11 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default now what ... cam sensor not working ?
Everything was working fine - so of course had to make changes!
Added FastLXR 102 and NW 102 TB now I hear the cam sensor is not functioning properly?
Is there something that can easily happen to cause the cam sensor problem (from your experience) when making above mentioned changes ?
This is an 2006 LS2 in my 2000 C5 convertible
It always helps to get input from the vast experience out here!!
Old May 29, 2011 | 10:53 AM
feeder82's Avatar
feeder82
the cam sensor is at the back of the manifold, it would be easy to mess the wiring up when changing the manifold
Old May 29, 2011 | 11:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! Check the connector and wires for damage/good solid connection..
Old May 29, 2011 | 01:23 PM
1stGlance's Avatar
1stGlance
Default Thank you for the input
Ok now I understand more of probable causes for this..
Car is at shop - but I just wanted to hear some ideas from the vast knowledge out here.
Thank you and much appreciated!!
To now what ... cam sensor not working ?
