havc code what is it B0361
Old May 30, 2011 | 11:16 AM
bigjohn19136's Avatar
bigjohn19136
Default havc code what is it B0361
any help here thanks
Old May 30, 2011 | 12:52 PM
PEERPSI's Avatar
PEERPSI
DTC B0361, B0363, B0365, or B0367
Circuit Description
The following DTCs are for the left and right air temperature actuators:
B0361 and B0363 are for the left air temperature actuator
B0365 and B0367 are for the right air temperature actuator
The HVAC control module commands the air temperature actuators to move by controlling the voltage supplied on the control circuit. A signal voltage of 0 volts or a signal voltage of 5 volts rotates the air temperature actuator. A voltage of 2.5 volts stops the door. The HVAC control module determines the current position of the actuator by monitoring the voltage on the signal circuit. The feedback potentiometer is a function of the motor position. The HVAC control module controls the air temperature actuator door positions in order to maintain the selected air temperature.
Conditions for Running the DTC
The ignition is turned ON.
Conditions for Setting the DTC
The HVAC control module detects the signal circuit is less than 5 counts (0.09 V), for B0361 and B0365, or more than 250 counts (4.9 V), for B0363 and B0367.
Action Taken When the DTC Sets
A default value will be used for the sensor data by the HVAC control module in an attempt to maintain the air temperature selected by the driver. This default value will be displayed on the scan tool.
Conditions for Clearing the DTC
The DTC will become history if the HVAC control module no longer detects a failure.
The history DTC will clear after 100 fault free ignition cycles.
The DTC can be cleared with a scan tool.
Diagnostic Aids
A disconnected or broken door may also set this DTC by allowing the air temperature actuator to travel to its internal stops, an overtravel condition. If condition not present, refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Tests for a default setting viewed by the scan tool.
Tests for the proper operation of the circuit in the high voltage range.
Tests for the proper operation of the circuit in the low voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to voltage.
Tests for a short to ground in the 5 volt reference circuit.
Step
Action
Values
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
1
Did you perform the HVAC Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - HVAC Systems - Automatic
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the appropriate Mix Mtr Position Feedback parameter in the Heating and Air Conditioning data list.
Does the scan tool indicate that the appropriate Mix Mtr Position Feedback parameter is within the specified range?
5-250 counts
Go to Step 3
Go to Step 4
3
Place the appropriate air temperature switch from the warmest position to the coldest position.
Does the scan tool indicate that the value of the appropriate Mix Mtr Position Feedback parameter remains near the specified value?
127 counts
Go to Step 4
Go to Diagnostic Aids
4
Turn OFF the ignition.
Disconnect the appropriate air temperature actuator.
Measure the voltage from the signal circuit of the air temperature actuator to a good ground.
Is the voltage more than the specified value?
4.90 V
Go to Step 5
Go to Step 9
5
Connect a 3 amp fused jumper wire between the signal circuit of the air temperature actuator and the low reference circuit of the air temperature actuator.
Measure the voltage from the jumper wire to a good ground.
Is the voltage less than the specified value?
0.09 V
Go to Step 6
Go to Step 10
6
Disconnect the fused jumper wire.
Measure the voltage from the 5 volt reference circuit at the air temperature actuator connector to a good ground.
4.90 V
Go to Step 8
Go to Step 7
7
Test the 5 volt reference circuit of the air temperature actuator for a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 16
Go to Step 13
8
Test the 5 volt reference circuit of the air temperature actuator for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 12
9
Test the signal circuit of the air temperature actuator for a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 13
10
Test the signal circuit of the air temperature actuator for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 11
11
Test the low reference circuit of the air temperature actuator for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 16
Go to Step 13
12
Inspect for poor connections at the harness connector of the air temperature actuator. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 16
Go to Step 14
13
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 16
Go to Step 15
14
Important
Perform the recalibration procedure for the air temperature actuator.
Replace the appropriate air temperature actuator. Refer to Air Temperature Actuator Replacement - Left or Air Temperature Actuator Replacement - Right .
Did you complete the replacement?
Go to Step 16
15
Important
Perform the recalibration procedure for the HVAC control module.
Replace the HVAC control module. Refer to HVAC Control Module Replacement .
Go to Step 16
16
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Document ID# 849041
2004 Chevrolet Corvette
Old May 30, 2011 | 01:35 PM
dmarkshark's Avatar
dmarkshark
Simply put, its the drivers side actuator. Does it have an H or C code after it?
Old May 30, 2011 | 03:10 PM
bigjohn19136
would having a vacume leak affect the actuator ?
Old May 30, 2011 | 03:11 PM
bigjohn19136
where is the actuator ?
Old May 30, 2011 | 03:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The actuator is located up under the driver's side footwell, right side on the hvac box itself. Its a pita to get too but it can be done. I did mine recently. Here was the cause of my code: Picture is of the driver's side actuator.
Old May 30, 2011 | 04:11 PM
BigGun's Avatar
BigGun
No.
Old May 30, 2011 | 07:27 PM
bigjohn19136
H also Bo441 H
Old May 30, 2011 | 07:32 PM
jrose7004's Avatar
jrose7004
H is for history, C is for current. The code is not current.
Old May 30, 2011 | 08:12 PM
dgrant3830's Avatar
dgrant3830
Clear the code and see if it comes back. When you clear it, this forces the actuator to reset and retest itself.
Old May 30, 2011 | 08:15 PM
bigjohn19136
thank you i cleared all codes i'll see tomorrow what happens
Old May 30, 2011 | 10:22 PM
dmarkshark's Avatar
dmarkshark
Just curious, you seem concerned with this code? Is there anything else happening with your AC system, or is all fine, but you have this code?
Old May 31, 2011 | 06:23 AM
bigjohn19136
air is not coming out the proper vents or i should say it's coming out all the vents at the same time
Old May 31, 2011 | 07:45 AM
dmarkshark's Avatar
dmarkshark
Is this a dual control unit? IF so, and you cannot control where the air comes from in either auto or manual, than it sounds like a vacumn leak. Let us know if that is the case, as someone here will step in and tell you where to look.
Old Sep 13, 2011 | 06:33 PM
bentvalve's Avatar
bentvalve
Default hmmmm!
My car suffers from a similar problem (02' zo6). Recently when i start my car about 85% of the time there is a loud vacuum leak or rushing air sound but once the motor runs for about 30 sec. or so the sound goes away. Or if I turn the A/C on while the sound is present it goes away and than returns if I turn it off
My A/C would start to blow cold than stop, I looked down at the A/C control and noticed the little orange light on the climate control would be blinking.
The car idols, runs and drives great
See profile for mods
Old Sep 13, 2011 | 06:42 PM
lucky131969's Avatar
lucky131969
Originally Posted by bentvalve
The car idols......
Old Sep 13, 2011 | 06:50 PM
bentvalve's Avatar
bentvalve
Default hahahaha
idles
Old Sep 15, 2011 | 11:48 PM
bentvalve's Avatar
bentvalve
anybody???
Old Sep 16, 2011 | 08:43 AM
dgrant3830's Avatar
dgrant3830
anybody???
You should start your own thread. If I was you, I'd be looking for a vacuum leak. Now if you are hearing this sound coming from the inside of the car, start there. But its its in the engine compartment, go there obviously. Pull your codes as a large vacuum leak will show up in the codes.
To havc code what is it B0361
