LS6 oil pump question
Old Sep 15, 2011 | 03:18 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Default LS6 oil pump question
What is the commom mistake that people seem to make when installing an LS1/LS6 oil pump. I remember something about the O-ring to be careful of, is that all? Also see output side is just metal oil pump surface to metal engine block with no gasket/no O-ring, is that right?
Old Sep 15, 2011 | 07:11 PM
Lothar34's Avatar
Lothar34
Pinching the o-ring and dropping the bolt into the oil pan are teh common mistakes.
Yes, metal-to-metal connection there.
Old Sep 16, 2011 | 03:06 AM
Vicarious.'s Avatar
Vicarious.
what are the first signs of this if it happens? Your engine pretty much siezes up pretty quick from no oil flow?
Old Sep 16, 2011 | 08:46 AM
FNFastZ06's Avatar
FNFastZ06
If the O-ring fails, you'll get reduced or no oil pressure. I imagine you'll hear the valve train clatter due to the lifters not getting enough oil before the bearings destruct.
Old Sep 16, 2011 | 09:10 AM
mchicia1's Avatar
mchicia1
Its very easy to install on a vette....it is hard to screw up. Go under the car on your back with your head on the radiator side of the car. You get a great view of everything from this angle. Just make sure the o-ring is seated all the way into the pump as you start tightening the pickup tube. It is obvious when you pinch it as part of the o-ring will be between the pump and the tube.
To LS6 oil pump question
