Voltage fluctuation question
Old Jun 2, 2011 | 08:31 AM
dcandel's Avatar
dcandel
Oldtimer
Default Voltage fluctuation question
I noticed yesterday that at idle, my digital voltage readout was fluctuating between 14.1 to 13.7 back and forth. At speed, it was reading 14.1. Is this normal or could there be an issue? I never noticed it doing that before.
Old Jun 2, 2011 | 11:21 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Both of those voltages are in spec. Sometimes loads thruout the car turning on and off and cause small fluctuations. If there are wide frequent voltage swings, it can be caused by other things:
The MOST COMMON area for wiring issues to cause charging system issues is the connections at the STARTER SOLENOID and loose or improperly connected battery cable connections..
The battery cable connectors need to be clean and torqued on the battery to 11 FT/LBS. (97-2003) cars..
I highly recommend cleaning and checking the connections at the solenoid. They come LOOSE A LOT and cause all sorts of voltage issues!
Something else to keep in mind. The voltage reading on the DIC and on the IPC volt meter IS NOT a battery voltage reading. Its a reading of the voltage THRU the IGNITION SWITCH! There can be a significant difference between the actual battery voltage measured at the battery terminals and the reading at the IPC/DIC readings.
Its caused by dirty ignition switch contacts inside the switch!
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
BC
Old Jun 2, 2011 | 04:14 PM
bsmutz's Avatar
bsmutz
Correct me if I'm wrong, but I believe the alternator doesn't put out as much at idle as it does at high revs. Definitely, both voltages are in spec and nothing to worry about, yet.
To Voltage fluctuation question
