Wtf not happy
Old Jun 3, 2011 | 08:25 AM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default Wtf not happy
So driving to work. No power steering, temp pegged and low voltage. Get to work and I notice the belt is slipped off cause power steering pully slipped forward ......... how the hell could this happen
Old Jun 3, 2011 | 08:56 AM
bsalie99's Avatar
bsalie99
your balancer is shot. the rubber inside has failed and the pulley part as slid forward. time for a new one
Old Jun 3, 2011 | 09:26 AM
dougbfresh's Avatar
dougbfresh
Old Jun 3, 2011 | 09:30 AM
Paul 75 L82's Avatar
Paul 75 L82
Oh, that's a fun job. Might as well put a cam in if your going to remove the balancer.
Old Jun 3, 2011 | 09:42 AM
didntdoit11
St. Jude Donor '12
The belt was on all the other. Pullys alt and tensioner just the power steering pully slid up on the shaft . Would it still be the balancer
Old Jun 3, 2011 | 10:28 AM
dougbfresh's Avatar
dougbfresh
Is the crank pulley wobbling?
Old Jun 3, 2011 | 11:33 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If in fact,, the Power Steering Pulley did slide on the pump shaft,,, its shot and needs to be replaced!! That sucker is a VERY TIGHT press fit. If it is indeed loose, it is most likely cracked or if your not the origional owner, it was removed and reinstalled imperoperly.
Take a couple pictures and show us what it looks like.
BC
Old Jun 3, 2011 | 12:21 PM
BigGun's Avatar
BigGun
No. There is no way anybody can tell if you need a balancer without looking at the car. From your description it sounds like you just have power steering pump or pulley problem.
Old Jun 4, 2011 | 12:43 AM
had2have-it's Avatar
had2have-it
My sons 99 frc had the pwr steering pulley move forward and spit the belt. The damn thing is plastic and adhered to a sleeve which fits over the pump shaft. You have a choice in OEM, plastic or steel and you probably know by now that the replacement job is involved
Old Jun 4, 2011 | 11:39 AM
mcm95403's Avatar
mcm95403
There was a billet aluminum set on E-bay a few weeks ago.
Here is the link: http://cgi.ebay.com/ebaymotors/LS1-L...Q5fAccessories
Old Jun 6, 2011 | 05:48 PM
didntdoit11
St. Jude Donor '12
Old Jun 6, 2011 | 06:08 PM
lionelhutz's Avatar
lionelhutz
Yup. looks like the pulley has fallen off the shaft of the pump. It's a pressed fit. You should be able to just replace the pulley.
Peter
Old Jun 6, 2011 | 06:33 PM
lucky131969's Avatar
lucky131969
Peter
Based on the shine coming off that pulley in the picture(and all the other polished parts)...it looks like an aftermarket pulley.....which may account of the poor fit.
Old Jun 6, 2011 | 08:58 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Time to replace the crank pulley. It has either separated or the bolt has come loose and the pulley walked off the shaft. Is there any oil under the car? If not, the pulley has probably just separated.
Old Jun 6, 2011 | 10:56 PM
lionelhutz's Avatar
lionelhutz
Huh? That picture is not the crank pulley.
Old Jun 7, 2011 | 12:07 AM
KCvetteowner's Avatar
KCvetteowner
You can use the LS3 power steering pulley, it's metal and a wagon wheel design vs. the plastic LS1/LS6.
Old Jun 7, 2011 | 12:41 PM
Z06ufgrad2002
Sorry, you are correct. Looks like the power steering pulley.
To Wtf not happy
