Where can I findthis cam?
Old Jun 4, 2011 | 02:00 AM
C4 Monster's Avatar
C4 Monster
Default Where can I findthis cam?
I cant find this cam anywhere.
Cam Spec: Comp Cam XER 110 LSA + 2 degress advance 224/228 588/588
Old Jun 4, 2011 | 07:51 PM
Greg_E's Avatar
Greg_E
Can't you just have Comp grind it? Granted you will pay full price, but you will have what you want.
Old Jun 4, 2011 | 09:26 PM
AU N EGL's Avatar
AU N EGL
What is with these specs?
you could do a 224/228 581/588 110+2
Old Jun 4, 2011 | 09:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Would this comp cam interest you??
PART # 8426
ENGINE: CHEVY LS1/LS6
GRIND # LS: 232/230
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .580 .580 1.7 RATIO ROCKER
.006 TAPPET LIFT
VALVE TIMING OPEN
AT .050 INT: 34 BTOC 70 ABOC
EXH: 73 BBDC 29 ATBC
THESE SPECS ARE FOR CAM INSTALLED
AT 109 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 232 230 SPRINGS REQUIRED
LOBE LIFT .3476 .3430 VALVE SPRING SPECS
LOBE SEPARATION 110
Old Jun 4, 2011 | 11:19 PM
ZZ06's Avatar
ZZ06
110??? Man you want that thing to hit hard
To Where can I findthis cam?
