GM crate LS3, drop in?
Old Jun 9, 2011 | 09:22 PM
87gtNOS's Avatar
87gtNOS
Default GM crate LS3, drop in?
Hey guys.
The GM crate LS376/480 6.2L appears to be a complete engine.
Is this a 'drop in' for the C5 Vette?
Or do you have another engine suggestion?
engine
http://www.gmperformanceparts.com/En...1224&engCat=ls
Old Jun 10, 2011 | 12:59 AM
austin@RPM's Avatar
0austin@RPM
Former Vendor
Almost a drop in. let me explain. The motor will bolt up to the stock mounts so it will drop in like that. The knock sensors will have to be moved to the side of the block. also the cam sensor harness will have to be extended to the front of the motor. i also think that crank reluctor is different so that will need to be changed through tuning i believe.
Old Jun 10, 2011 | 02:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
"crank reluctor is different so that will need to be changed "
All the above needs to be addressed BUT,,,,,,,,,,,,,,,,,,,,,, THIS,,,,,, is your biggest issue:
Until you do that...... dont even think about dropping it in...
BC
Old Jun 10, 2011 | 06:02 AM
crainholio's Avatar
crainholio
Lingenfelter sells a translator box to address the reluctor incompatibility.
To GM crate LS3, drop in?
