Excessive pinging mystery
Old Jun 15, 2011 | 10:12 AM
Peixinho's Avatar
Peixinho
Default Excessive pinging mystery
Alright well I have searched and tried everything I can think of so now I need to ask you guys for help.
I have a 1998 c5 manual with about 80,000 miles on it... I have a little bit of excesive pinging that is really starting to bother me. I have looked up a lot of different things to try but I can't find a solution. The only check engine light I have is p1441 and that only comes on every once in a while... from what I have seen it is unrelated and the pinging came before the p1441 code (although I am trying to get that fixed)
Here are the symptoms. In almost every gear when I first tap the pedal to accelerate I hear a little pinging that goes away after just a split second, it is definitley wosre at lower rpms but seems to be pretty consistent... that does not bother me too bad but when I floor it through the rpm range it I will hear it ping a little bit, go away, and then come back near the top end and will last for about 2 seconds if I don't let off the gas right away (no i don't drive it like that all the time, I am just trying to diagnose what is wrong). The pinging is definitely worse at higher operating temperature and has gotten worse since summer hit. I believe that is because the engine is running hotter and the air temp outside is hotter.
Here is what I have tried so far...
  • New knock sensors, wire harness, and new wiring to the PCM
  • I ran MCCC (mopar combustion chamber cleaner) as listed here on this site
  • New spark plugs
  • Clean MAF sensor
  • I have checked as best I can for a vaccum leak. there is nothing audible and I have checked all connetions I can see
  • I have ran seafoam through a couple of tanks
  • I always run chevron premium
  • I have tried octain booster and it does not affect it whatsoever
well does anyone have any ideas on where to go from here
Old Jun 15, 2011 | 10:23 AM
Paul Wood's Avatar
Paul Wood
Do you have a reputable tuner in the area that could look at fuel trims and other related settings? Pinging is a fuel issue in my mind but I am not an expert. Have you looked at your injectors? Fuel rail pressure?
Old Jun 15, 2011 | 11:03 AM
Peixinho's Avatar
Peixinho
I don't know any tuners... to be truthful I have never modded my vette, or any othe car for that matter. The car is stock except for CAI...
I will have to look into fuel pressure. Other than the pinging the car seems to run great... idles perfect, accelerates well...
Old Jun 15, 2011 | 11:42 AM
Mickee's Avatar
Mickee
Hi!
Had sort of the same problem last year, got a massive -10 degree knockretard when pushing it.
I finally found a coilwire that separated in the middle of the cable when i tried to remove it to put new wires on. Hasn't pinged since
/Mike
Old Jun 15, 2011 | 11:44 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The car should be logged to be sure of A/F etc first, but also try directly injecting SeaFoam into the engine via a vacuum hose. I use the EVAP line myself. Let it sit for 30 minutes to an hour and start it up. It will smoke like you blew a head gasket for a while, but it is much more concentrated then going in the tank, and can sit on the piston tops dissolving the grime away.
This takes some finesse, you do not want to hydrolock the engine, just keep it sputtering while ingesting it, and have someone ready to shut the car off right as you empty the bottle. It works wonders.
Old Jun 15, 2011 | 12:16 PM
Peixinho's Avatar
Peixinho
Great technique and I was about 95% sure that was going to work... I actually tried the MCCC and the Sea foam and neither produced any results...
Old Jun 15, 2011 | 12:17 PM
Peixinho's Avatar
Peixinho
Originally Posted by Mickee
Hi!
/Mike
Maybe i should replace all my wires now too... what were your symptoms... you said is was sort of the same problem
Old Jun 15, 2011 | 12:25 PM
Mickee's Avatar
Mickee
Well the most apparent was that it stopped pulling in higher rpms, and got some codes, cant exaclyt remember them now, was over a year ago.
Also got some strange "losing idle" for a split second then it reacted and got up to 6-700rpm.
Stuff like that
/Mike from Sweden
Old Jun 15, 2011 | 07:50 PM
Peixinho's Avatar
Peixinho
anybody have any other ideas or insight on the subject
Old Jun 15, 2011 | 07:59 PM
fishmen222's Avatar
fishmen222
Read the post titled "Newbie with a few questions" right below yours as I am having a similar issue minus the top end detonation.
Old Jun 16, 2011 | 02:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Another PING/KNOCK post:
http://forums.corvetteforum.com/c5-t...questions.html
Old Jun 16, 2011 | 02:58 PM
dougbfresh's Avatar
dougbfresh
Pinging (pre-detonation) is "usually" caused by a LEAN condition or carbon deposits on the intake valves or pistons. The easist thing to try 1st if to Seafoam the beast and see if your carboned up. The bits of carbon get hot and preignite the fuel charge.
Old May 16, 2012 | 01:01 PM
Peixinho's Avatar
Peixinho
read all of these posts for some more updates and a fix to the problem
http://forums.corvetteforum.com/c5-t...pt-a-tune.html
To Excessive pinging mystery
