single wire water temp gauge
Old Jun 15, 2011 | 11:12 AM
ls1jeep's Avatar
ls1jeep
2nd Gear
Default single wire water temp gauge
is there any way to tap a single wire gauge into the stock engine coolant temp gauge wiring ?
Old Jun 15, 2011 | 11:24 AM
lucky131969's Avatar
lucky131969
I would suspect that most aftermarket gauges operate on 12 volts, while the C5 ECT is 5 volts. Additionally, you cannot tap into the existing circuit, as that would affect the resistance.
Old Jun 15, 2011 | 11:30 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I don't think the +5 volt reference signal used would be compatible with an aftermarket temperature gauge, and it might cause damage to the PCM.
You could probably drill and tap the thermostat housing, to accept your aftermarket sensor, and then wire it as a stand-alone device.
Old Jun 15, 2011 | 11:37 AM
Quicksilver Vert 01
It looks like lucky was already typing, while I was looking the circuit up in the shop manuals.
Seems like we both agree that it's a bad idea to tap into an existing +5 volt circuit.
Old Jun 15, 2011 | 11:41 AM
lucky131969
I think an easier solution, would be to make use of the other head. Just remove the plug.
Old Jun 15, 2011 | 11:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you want an aftermarket temp guage, why not just install one on the PASSENGER HEAD in the EXACT same hole that the C5 temp sensor is in? Theres a PLUG in that hole! It's at the rear location on that head on that side of the engine.
BC
Old Jun 15, 2011 | 12:02 PM
Quicksilver Vert 01
Heads win....It's a perfect location to use!
To single wire water temp gauge
