Program/ tuner question.
Bob
Someone sat down and figured out what changes that LSX engines respond to and incorporated them into a Hand held device TUNE.
Is that persons idea of generic tune for your LS engine going to be good for your engine and the MODs that you have installed?????????
When you add modifications to any fuel injected engine, you change the way that the engine breaths. One of the PCM tables that models the way that the engine breaths is the VLOUMETRIC EFFICIENCY (VE) Table. There’s NO WAY that a canned tune can accurately change that table if it needs adjusting. Another value that it can NOT accurately adjust is the Power Enrichment (PE) table that controls your WOT Air Fuel Ratio (AFR).
Tuning Software like EFI Live or HP Tuners allows you to data log and customize just about every table or tuning value that GM used to program the PCM. The drawback is,, the learning curve to be able to correctly change all those parameters CORRECTLY is pretty much VERTICAL !(for me anyway!
) That software is also a little pricey.I have EFI Live V2 and I also have good friends that are GODS with tuning!
I’m on call 24/7 for their C5/C6 electrical issues and there on call for MY TUNING needs! Can’t get much better than that!
BC
I was able to tune out CAGS,adjust my fans and get my LTFT's in line.If I added any bolt ons,I would certainly get a custom tune.
Knowing your expectations will guide you to the right tuning route for your car & mods.
IMO.......
\db2
carolina
http://forums.corvetteforum.com/c5-s...nly-149-a.html
