The Ultimate Oil Filter?!!
Old Jun 21, 2011 | 10:51 AM
crainholio's Avatar
crainholio
Originally Posted by wcsinx
Ecore?
No, really, allow me:
http://lmgtfy.com/?q=ecore+delco+filter
Old Jun 21, 2011 | 10:53 AM
Kale's Avatar
Kale
No love for Mobil 1 filters?
Old Jun 21, 2011 | 10:59 AM
jd86L98's Avatar
jd86L98
I learned my lesson with inexpensive oil filters two weeks ago when I started to get a low oil pressure warning on startup and fluctuations while driving. Replaced the Jiffy Lube filter with a Mobil 1 high capacity filter and back to normal. I think the cheap filter internally collapsed after a strong weekend canyon run.
Old Jun 21, 2011 | 03:19 PM
oh1vette's Avatar
oh1vette
Originally Posted by LIGHTNING
According to the article in the Aug issue of VETTE Magazine, they do.
yeah I saw that in VETTE too......turned the page....
Old Jun 21, 2011 | 03:27 PM
wcsinx's Avatar
wcsinx
Originally Posted by crainholio
Oh well right back atcha, jackazz!
http://maps.google.com/maps?q=Advanc...,0.154324&z=13
Sorry if I'm not hip to your non-standard terminology, and I didn't care enough to translate it. It's like saying, I use the shooba-dooba-super-hoopy filters (but everyone else calls them Purolator). No I won't explain my terminology. Look it up you lazy f**kers!
Old Jun 21, 2011 | 03:29 PM
wcsinx's Avatar
wcsinx
M1 filters are good stuff, but they charge a premium. Wix and PurOnes are just as good IMHO and significantly cheaper.
Old Jun 21, 2011 | 03:46 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by SaberD
if you do buy one of these, check your oil pressure before and after install at the same temp. depending on if you did the oil pressure sensor relocator or not, the pressure may increase or decrease. this will let you know if it is putting additional strain on your oil pump. most people dont run purolator oil filters on vettes due to this reason.
PureOne oil filters probably flow better than most. The PSID is actually pretty low for being able to flow so much oil volume.
Read this:
http://www.bobistheoilguy.com/forums...2088643&page=1
(i cant remember if the sensor relocate puts the sensor before or after the filter in the system, so i'll let you figure that one out )
A correctly designed oil pressure relocation kit will put the sensor after the filter, just like the OEM location.
Old Jun 21, 2011 | 03:51 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by Oldvetter
The stock C5 oil pressure sensor is located AFTER the oil filter, so higher pressure equals less restriction and more flow.
I stopped using DELCO Premium UPF filters because they were too flow restrictive, went to WIX filters. My cold oil pressure increased 10-15 psi.
The only time you should be able to see the effects of a more or less restrictive oil filter is when the oil pump is in pressure relief mode (ie, when the max oil pressure point is achieved and some oil is being shunted back to the sump). I'm assuming you mean your max cold oil pressure (at some higher RPM above idle) was 10-15 higher.
I've used about 4 different brands of oil filters on my Z06, and all have given me the same exact oil pressure at the same oil temp & RPM points.
Old Jun 21, 2011 | 08:50 PM
crainholio's Avatar
crainholio
Yes that's right, I'm the guy who thinks up Delco's naming standards.
Personally, I like your nomenclature much better than "ecore". You're getting the first PF47-shooba-dooba-super-hoopy off the assembly line.
Old Jun 21, 2011 | 09:48 PM
wcsinx's Avatar
wcsinx
First of all, it's a term from Champion Labs not Delco. Delco started selling repackaged Champion filters, but they did not come up with the term "Ecore". Perhaps if you actually had googled it, you would know that.
Second, if I pick up an "Ecore" filter at Wal Mart, does it say "Ecore" anywhere on the box? Nope, that's an internal term. The box is labeled "Supertech". And that is how most people would refer to said filters. Is there a reason, other than to be presumptuous, to refer to them as anything else?
Old Jun 22, 2011 | 05:54 AM
crainholio's Avatar
crainholio
I think you have your helmet strap a lil' too tight.
Sorry if you weren't able to communicate clearly by this:
Sorry if I'm not hip to your non-standard terminology..
Just sayin' it's not my terminology. And now that you're The World's Leading Expert on filters, I'm sure you understand this.
Delco filters say Delco on the box, not Supertech. Delco Ecore filters have an "E" suffix on the part#, eg. PF-47E.
Old Jun 22, 2011 | 06:04 AM
dbaker's Avatar
dbaker
Using great oil with cheap oil filters doesn't make sense to me.
I'll stick with either the Wix 51042 or the Amsoil Ea15k32.
Wix:
http://www.youtube.com/watch?v=6BQha9MSM-U
Amsoil:
http://www.youtube.com/watch?v=EAmfwTvZx7M
\db2
carolina
Old Jun 22, 2011 | 09:11 AM
  #33
wcsinx's Avatar
wcsinx
W/e you knew exactly what I meant in that it is not the consumer facing market terminology.
I don't think this supports your position. And I've never seen Delco filters at Wal Mart just Supertech (which are the same thing anyway) and Fram. Do your local Wal Marts have Delco branded filters on the shelves?
Old Jun 22, 2011 | 09:58 PM
  #34
crainholio's Avatar
crainholio
The three Wal-Marts in my area have Delco, Fram, Supertech, and a few Motorcraft on the shelf. I still like Motorcraft FL820S for the wife's car but Delco "E" pieces are a no-go after seeing how they're built.
