From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Is this a trick question? The 01-04 intake manifolds flow better than the 97-00. People call them "LS6 manifolds" but from 01-04 LS1's and LS6's had the same intake manifold.
Reason: I spell like a 2 year old......
Is this a trick question? The 01-04 intake manifolds flow better than the 97-00. Peope call them "LS6 manifolds" but from 01-04 LS1's and LS6's had the same intake manifold.
So 2001-2004 have same intake (LS6)?
YES but the ZO6 has a different throttle bottle and heads then the Coupe or vert
