Steering rack removal help
Old Jun 28, 2011 | 07:18 PM
m6 c5's Avatar
m6 c5
Default Steering rack removal help
Is there a special way that you are supposed to get the rack out of the ears or tabs that it bolts to on the cradle? Mine is stuck in there and wont budge on the passenger side, the drivers side is as you would expect and will move up and down freely.
Any suggestions or tips would be very much appreciated.
Oh and yes I did take the bolt out.
Old Jun 28, 2011 | 11:09 PM
Underdogg's Avatar
Underdogg
just a pry bar and a little force. it will come right out. you dont have to be gentle but dont hit it with a hammer either...
Old Jun 28, 2011 | 11:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a metal spacer in the bushing... MAKE SURE that its not catching in the ear hole... The ears BREAK EASILY!!!!
Old Jun 29, 2011 | 12:03 AM
m6 c5's Avatar
m6 c5
I have used pry bars, handles of hammers to pry on, and pieces of wood that I hammered on to get it to slide and it hasnt budged at all not even 1/16th. The bolt still goes in with ease on both sides.
I will check the spacer tomorrow morning when I take another go at it but it did not appear to me that anything was catching in hole of the ear. Im hoping that I can run up to zip tomorrow and get a rebuilt one...
Old Jun 29, 2011 | 12:17 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The people at ZIP are excellent... Your in great hands if you go there!!
BC
Old Jun 29, 2011 | 12:27 AM
m6 c5's Avatar
m6 c5
BC
Yes they are I have spoken with them a few times but if I cant get this rack out well Im not sure what Im going to do.
Old Jun 29, 2011 | 06:50 AM
VET IT B's Avatar
VET IT B
I had a awful time with mine as well. What worked best for me was a 3' long pry bat and I worked it in between the cradle ears between the rack and cradle from the passenger wheel side. Directly in from the end. My bar was just narrow enough to go in between the ears from the end and pry straight up. I ended up loosening the cradle bolts to give me enough room to get it to clear and remove. Hope that helps. Mark
Old Jun 29, 2011 | 10:50 AM
m6 c5's Avatar
m6 c5
Yes I saw your thread and the troubles you had... its almost like the spacing between the ears is way too small and its just holding it in there. I am going to check and make sure that spacer is not catching when I go back out there.
Ill post back up with the results.
Old Jun 29, 2011 | 05:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What ever you do,,, DO NOT pry the ears apart and DO NOT twist the rack. If you do,, they will SNAP OFF! That will NOT be a good day event!
Old Jun 29, 2011 | 07:16 PM
01vetter's Avatar
01vetter
I had the same problem as you have when I raised my rack to pin my crank. Like others mentioned I used a crow bar between the cross member and the rack to free it up. I used a small wood block under the rack to prevent denting its shell. It wasn't easy but it eventually came free.
I also had a problem inserting the rack into the cross member ears, even though I used generous silicone lubricant on the rubber bushing. I had to use a 2x4 coming down from the top and a hammer to bang it in.
I now have to remove my rack to adjust it. I am going to try to use a nylon tie down strap extending down from a 2x4 in my engine bay going around my rack. I have a BMW tire jack that I will use on top the the 2x4 to pull the rack up. I may still have to use a crow bar, but hopefully the tie down strap will exert enough upward pressure to help free the rack. I also will use the same procedure to pull the rack into the cross member ears by placing the strap around the top of the rack and using the BMW jack on the bottom of the cross member.
Hope this may help.
Old Jun 29, 2011 | 07:24 PM
m6 c5's Avatar
m6 c5
Hope this may help.
Yea I am having loads of trouble getting it out I have moved it maybe a 1/4 inch using a crow bar that is 3 or 4 feet long. I have sprayed it with pb blaster in hopes it will soak in and let it slide a little easier but so far it hasnt really helped. Im not sure how you are going to use that 2x4 but I have been trying to come up with a way to do the same thing, too bad I dont have the engine lift over here or else I would pull it straight out with that.
At this point Im almost all out of ideas so if anyone has any suggestions I am willing to try them.
Old Jun 29, 2011 | 09:13 PM
01vetter's Avatar
01vetter
Default 2x4 position
I have a super charger on the right hand side of my engine. I will position the 2x4 on the top of the super charger going across to the top of the alternator. Since you probably don't have a super charger on the right hand side, is there room to run a 2x4 vertically down to the ground on the right hand side of your engine bay? You could then run a 2x4 horizontally from the top of your alternator to the vertical 2x4. Just a thought.
Old Jun 30, 2011 | 08:39 PM
Rex99Coupe's Avatar
Rex99Coupe
Any luck removing the rack?
Old Jun 30, 2011 | 09:07 PM
OutKlast's Avatar
OutKlast
Those damn metal slugs in there have caused me trouble everytime I removed the steering rack.
My solution was to put a jackstand in the space between the front crossmember and the leaf spring on one side. On the other side I took out the top of a jackstand and balanced on my hydraluic jack. I then made a bridge with a piece of metal that crosses under the steering rack. Then I slowly jacked the "bridge" up to put pressure on it. I just lift it a little. From there I use a screwdriver to gently tap at the metal slug inside the hole. It usually slides enough and the car will drop back down. You'll also want to just slide the drivers side rack bolt back in and try to get this "bridge" as close to the passenger side bolt as possible.
I've done it like I mentioned above with a jackstand on the ground, and just the white top metal part of the jack stand balanced on the hydraluic jack. I've also done it with 2 jackstands balanced on a board. Neither is easy... or elegant. An engine crane would probably do the same job, but I didn't have one so redneck engineering came into play.
!! Also note these photos are for illustration purposes, they're not on the correct side, but the rack had finally come out and there was no way in hell I was going to risk letting it fall back in. !!
Old Jun 30, 2011 | 09:10 PM
01vetter's Avatar
01vetter
M6 C5, I used the nylon strap with a 2X4 as mentioned above today and it easily pulled my rack up! To be fair, I had my rack up about 3 years ago so that may have helped. But it worked so well I encourage you to try it. This method is also puts much less stress on the rack compared to using a pry bar. As I mentioned you could position the 2x4 on top of the alternator and on top of a vertical 2x4 positioned on the right front side of the engine going to the ground. It is worth a try.
Also, do you nave the two 18 MM power steering lines disconnected? These would prevent you from raising the rack. One of these lines is also attached to the front of the cross member by two clamps. Unscrew the bolts that attach the clamps. That may help add some flexibility.
Old Jul 2, 2011 | 12:23 AM
m6 c5's Avatar
m6 c5
Well I ended up putting it back in place mainly because I was tired of messing with it and didnt feel like spending anymore money after I found some things that had to be replaced and took priority over a rack that was leaking a little. I will replace it later on this year. I think I might try to either get the engine lift or use the jack stand route as I dont feel too comfortable using a 2x4 from the ground as it doesnt seem too stable to me. If I had a super charger Im sure it would work really well.
To Steering rack removal help
