No start
Old Jul 18, 2011 | 01:40 PM
william mikesell's Avatar
william mikesell
Originally Posted by Bill Curlee
Well,,,, If it were me, and as much as it cost for a BCM and you will have to get any RPO Codes programmed into the new BCM with a GM Tech 2 and sync it to the BCM,,,,, I would remove the BCM, open it up, remove the board, examine the circuit board and if that looks good.. probe the BCM fuses to make sure that there not blown and the fuses have the correct voltage on EACH or the three fuses.
Check the fuses FIRST! Use a METER and see if theres battery voltage on each fuse..
BC
Bill
Bill: I am not sure you got my previous message. Replaced the BCM with a used one supplied by a forum member at the very resonable price. Plugged it in , completed the re learn procedure and it started . Cleared the existing codes and ran diagnostics all "No Codes". I would be happy to send you the old BCM if you would like check it out. At any rate a heartfelt thanks for your kindness and expertise.
All the Best.
William
Old Jul 18, 2011 | 03:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
PM SENT.
Thanks again and glad you got it back on the road!!
Bill
