security light on
Old Jul 3, 2011 | 11:11 PM
aviatorwes's Avatar
aviatorwes
Default security light on
My security light is on while driving, just came on the other day. No difference in drivability or anything just wondering why it would be on.
Old Jul 4, 2011 | 12:57 AM
Jnape's Avatar
Jnape
Usually this will inhibit starting. typically the pellet key and reader aren't sending the right value to the computer. Can be a bad or dirty key resistor. Bad sensor on the ing switch (not the switch itself).
Pull your codes and see what is reporting an issue.
Old Jul 4, 2011 | 01:05 AM
aviatorwes's Avatar
aviatorwes
Ok I will pull codes in the morning.
Update; drove hone from the buddies house and noticed the light wasn't on. I will still check for codes tomorrow though
-wes
Old Jul 4, 2011 | 01:16 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Yeah, you could be starting to see the results of wear on the ignition cylinder, or on the resistor pellet. Something like that - jiggling the key can make the security light turn off; so can cleaning the key.
I know there's a recommended way to clean the ignition cylinder contacts but I can't remember what that is...
Old Jul 4, 2011 | 07:49 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If the codes reveal the key pellet causing this, do you have lots of things on the key chain hanging there? We've seen this causing issues with the internal contacts.
To security light on
