3 rib differential VS 1 rib
Old Jul 5, 2011 | 11:14 AM
dgoetz's Avatar
dgoetz
Default 3 rib differential VS 1 rib
I am wanting to put a 3:15 1 rib Diff in my 04 C5 ZO6. What is the difference? Is it just weaker and how much. I don't drag race but autocross. My starts are fairly easy, I don't dump the clutch and very little shifting if any but I am runnig 335x17 A6 Hooisers. Any forseen problems?
My class does not allow changing gears only the complete components
Old Jul 5, 2011 | 12:01 PM
vettenuts's Avatar
vettenuts
Not sure I understand why. The Z06 rear has more internal differences then just the ratio.
Old Jul 5, 2011 | 12:42 PM
DIXZ's Avatar
DIXZ
As far as strength goes, a one rib diff will be fine for your application.
Old Jul 5, 2011 | 04:30 PM
dgoetz's Avatar
dgoetz
like what? I have to use the complete component not just the gears or I would install 3 :15 in mine.
Old Jul 5, 2011 | 05:50 PM
vettenuts's Avatar
vettenuts
Gears are shot peened for strength are one thing. Can't remember all the details. Why a higher ratio?
Old Jul 5, 2011 | 05:59 PM
SLVRCPE's Avatar
SLVRCPE
I dismissed chasing the 3 rib when looking for a replacement rear for my car (going from 2.73 to 3.42). However, I lucked out and the unit I bought was a 3-rib, seller did not indicate this or I probably would have been outbid.. Anyway for my power level ~ 500rwhp, either would be fine. Thing is there are so many 800+ HP cars on this forum the topic comes up alot. For your application I would not think twice about running the one rib.
Old Jul 5, 2011 | 06:51 PM
dgoetz's Avatar
dgoetz
Why a higher ratio?
Most of our courses are on High School parking lots. 30 to 45 sec courses. the MM6 C5's with a taller 1st gear can do the whole course without shifting where i either have to shift back and forth or let it hit the rev limiter at 1 or 2 places on the course. The same with the C6 ZO6's. Plus first gear would be easier to drive if it was taller.
I can try it pretty cheaply so it is worth a try.
To 3 rib differential VS 1 rib
