tcs/abs light
Old Jul 9, 2011 | 09:38 PM
I dream of vettes's Avatar
I dream of vettes
Default tcs/abs light
So every so often over the past few months the tcs/abs light would come on while driving. After stopping and resuming drivingt, the lights would turn off. Now, every time I start the car and begin driving the tcs/abs lights come on within 1-4 minutes. I cleared the codes, drove the car and the only code the DIC displayed was TCS c1225h. I was wondering what this code meant and what is the first thing to check/possible issues? Thanks for any help!
Old Jul 9, 2011 | 10:14 PM
cdkcorvette7's Avatar
cdkcorvette7
1225 is excessive wheel speed variation at the left front wheel. Sounds like your LF wheel speed sensor might be on it's way out...
Old Jul 10, 2011 | 12:38 AM
BigGun's Avatar
BigGun
The sensor is usually not the problem. It is almost always in the connectors or wiring. On mine the wire was broke inside the insulation at the connector coming out of the hub.
Old Jul 10, 2011 | 03:24 AM
DeeGee's Avatar
DeeGee
Its worth pulling the electrical connector to the sensor on the back of that hub. Give the connector a good clean and see if it improves.
Old Jul 17, 2011 | 08:31 PM
I dream of vettes
So I checked the sensor. The wires all seem to be firm in place and I tried to clean the plug. Unfortunately it didn't seem to help. Would getting a new sensor be the next step?
Old Jul 27, 2011 | 10:12 PM
I dream of vettes
bump
Old Jul 28, 2011 | 10:08 AM
BLUE Y2K's Avatar
BLUE Y2K
I had the same problem and had to replace a front wheel bearing. No problem since then.
Old Jul 28, 2011 | 11:12 AM
BigGun's Avatar
BigGun
Did you use a meter and check the resistance as the service manual suggests. Really easy to do, you don't even have to jack the car up. Those sensors are just a roll of wire so pretty much bulletproof. You have to replace the whole hub if you indeed have a bad sensor.
To tcs/abs light
