No Reverse...
Old Jul 10, 2011 | 12:33 PM
MotleyDrew's Avatar
MotleyDrew
Default No Reverse...
Hey guys
I have been fighting this for awhile. I have no reverse...[I]ts not even selectable and cannot be forced in...its like it doesn't exist. I have a 2001 Z06 wit an M6 RPM style built tranny. I have tried adjusting the Tick master and once before this helped and reverse was smooth as silk but then was gone again after a short while. I fully replaced and bled the master as well as replaced the reverse lockout solinoid. I am getting 12.06 volts to the wiring on the ;\lockout solinoid so this is not the issue. When reverse was working it never grinded and felt fine. Now its been gone for a few months with no ryhm or reason. No sure what to check next. I have a dual ACT clutch and B&M Sport shifter as well. I do notice that ever since replacing my tranny from the M12 version that my shifter has 2 nuetral positions and gates are further apart but the tranny seems fine other than no reverse.
Tranny has
carbon syncros
billet keys
bronze pads
steel shift fork
cryoed gears
cryoed 30 spline output shaft stock is 27 spline
please let me know what you think as this is getting very frustrating,
thanks
Old Jul 10, 2011 | 12:55 PM
sfc rick's Avatar
sfc rick
It's the shifting fork that lost the plastic tips that fits into the shifting collar groove. Had it happen to me. Look at this pic and see the black plastic tips? It's a crappy design.
Old Jul 10, 2011 | 01:02 PM
MotleyDrew's Avatar
MotleyDrew
thanks very much Rick !!! I guess this means the tranny has to be pulled
Old Jul 10, 2011 | 01:05 PM
sfc rick's Avatar
sfc rick
Yep!
And since it does have to come out......R&R your clutch,flywheel,pressure plate, slave cylinder since it's right there.
Edited: But I see you just installed new clutch and stuff, so ignore my advice on the clutch and flywheel.
Old Jul 10, 2011 | 02:34 PM
MotleyDrew's Avatar
MotleyDrew
Originally Posted by sfc rick
Yep!
I have had my car apart about 3 times in the last 5 years....I had everything just how I wanted it now this...F&*k. I have someone who can fix it qoiuck just need to find time to pull her out...may be awhile
thanks again Rick !
Old Jul 10, 2011 | 03:22 PM
Warp Factor's Avatar
Warp Factor
Probably not, because his plastic parts have already been replaced with bronze ones by RPM.
If it was a clutch disengagement problem, I'd think you'd have a problem engaging first too.
Old Jul 10, 2011 | 03:38 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I just finished installing a clutch 3 times after having engagement/disengagement problems. I measured the distance between the fingers and throwout bearing after discovering it was slightly out of tolerance. I made a .065" sheet metal shim and placed it under the slave. It calls for a space between .100 and .225". Doing that moved the point of full engagement, but it still wouldn't shift into reverse. The way to tell if you have an engagement problem is to jack up the rear, start the car, push in the clutch, put it in 1st and if the wheels turn, your clutch is dragging. Another test I did was to try to put it in reverse and while holding the shifter in that attempt, I would turn the car off. It would pop right in with the car off. I was warned that the clutch manufacturer would test it, replace everything, but tell me there was nothing wrong. After getting the replacement back, it worked perfectly.
Old Jul 10, 2011 | 05:35 PM
thekid96's Avatar
thekid96
I would try adjusting the bushing that ties the shifter in to the shift rod before pulling anything. I had the same issue and solved by adjusting the bushing. I found it to be VERY sensitive, took several attempts to adjust properly.
Old Jul 10, 2011 | 06:33 PM
MotleyDrew's Avatar
MotleyDrew
thanks guys.......this is driving me nuts.....i will start trying some of things you have mentioned
even with car off i cannot put it in.
Old Jul 10, 2011 | 06:41 PM
MotleyDrew's Avatar
MotleyDrew
when you say bushing do you mean the plastic piece that seats in the shifter rod?
thx
Old Jul 10, 2011 | 06:57 PM
thekid96's Avatar
thekid96
No, there is a sleeve behind the shifter that couples it to the rod that goes to the trans. The sleeve is adjusted with an allen wrench and controls the pitch of the shifter and the feel of the gates. Mine moved a bit to the left towards first gear and I could no longer shift into reverse. Loosen the allen bolt and move the shifter left and right and you will figure out where it needs to be to get all gears shifting/feeling proper. One other note, how tight you lock down that allen bolt also effects the feel of shifting. Took me about half an hour to get it right but my car shifts so much better than it ever has. I spent five years literally muscling it into reverse with two hands and thinking it was a clutch dragging problem.
thx
Old Jul 10, 2011 | 07:26 PM
BLOWNBLUEZ06
Sounds like you're talking about an aftermarket shifter.
Drew,
I expect that even if the reverse lockout solenoid were broken, it would still let you engage reverse with the car turned off. I have seen the collar come loose on the shifter adjustment before, but that only created a situation where you had to push it hard over to the right to engage reverse. RagtopWS6 (aka Rick Kim from RKT56.com) is a supporting vendor and one hell of a trans builder and great guy. You might PM him for ideas as well.
Old Jul 10, 2011 | 09:08 PM
thekid96's Avatar
thekid96
The collar I am talking about is the same regardless of the shifter. When my collar came loose, as you reference, I physically could not get my trans in reverse, not possible. Depending on how you adjust the collar radially, you can lock it too far in either direction and loose 1st/2nd or reverse. Definitely an easy 5 minute deal to check it before he pulls anything apart.
Drew,
Old Jul 10, 2011 | 10:26 PM
MotleyDrew's Avatar
MotleyDrew
thanks guys...i will be checking the collar out when i install the new mgw shifter....this would be awesome if this was the fix
thanks guys and as always my boy Bret
Old Jul 11, 2011 | 07:54 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Hey guys
Tranny has
carbon syncros
billet keys
bronze pads
steel shift fork
cryoed gears
thanks
Pull the plug on the reverse lock-out to de-activate it and see if that helps.
Also try aligning your shifter again and see if that helps.
If not, I would look at Bret's suggestion and pull your inspection plate and check the air gap on the clutch as it could be dragging some.
Old Jul 11, 2011 | 12:27 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Hey guys
Tranny has
carbon syncros
billet keys
bronze pads
steel shift fork
cryoed gears
thanks
Try this for me. Remove the reverse lockout solenoid (remove the 13mm bolt holding the solenoid to the "dog house" on the top of the trans) and see if the trans goes into reverse. If it does, then it's the angular piece the reverse solenoid screws into. There is a large push pin that can be pushed back when the reverse solenoid retracts but when this pin gets stuck, there is no way to get it into reverse. try that and post your findings.
__________________
Old Jul 12, 2011 | 11:15 PM
MotleyDrew's Avatar
MotleyDrew
thanks guys......i am going to try these things hopefully this weekend and i will post findings
thanks a bunch
To No Reverse...
Old Aug 27, 2011 | 09:36 AM
MotleyDrew's Avatar
MotleyDrew
Issue resolved ! Thanks everyone for the help. "TheKid96" gets the win !!! I adjusted the bushing and tightened up and all is great!
thanks !!!
Old Jun 30, 2025 | 05:13 AM
C5drifter's Avatar
C5drifter
Necro thread but
The same thing has happened to me (no reverse with car off or on), just after installing an aggressive cam, I suspect the increased vibration has moved the collar.
Is that the allen key bolt you use to adjust the sleeve on the lower right corner of the picture below?
Old Jun 30, 2025 | 08:43 AM
lucky131969's Avatar
lucky131969
Originally Posted by C5drifter
Necro thread but
