CAM question...need help
Old Jul 11, 2011 | 03:36 PM
dheide's Avatar
dheide
Default CAM question...need help
Hey guys can I run this...Comp cam .608/.615, 240/248 on the stock heads? What about manifolds? what will I need to upgrade and how much am I looking at if I put this in?..Thanks !
Old Jul 11, 2011 | 03:45 PM
AU N EGL's Avatar
AU N EGL
Very tall lift with large duration
most likely your pistons will need to be checked for clearance and fly cut
as is not likely to fit
Old Jul 11, 2011 | 03:51 PM
dheide's Avatar
dheide
Default called comp cams
I called comp cams and they said I wont have a problem with this cam as long as I get double springs and new pushrods it should be fine...since it is their cam and I dont trust the people who sell their own products I am a little skeptical so....help?
Old Jul 11, 2011 | 04:44 PM
SDPC's Avatar
0SDPC
Former Vendor
You will HAVE to check PTV clearance, it's going to be very tight. If it were my car, I would flycut when installing that cam with stock pistons no matter what the PTV numbers are.
Old Jul 11, 2011 | 04:47 PM
dheide's Avatar
dheide
How the heck do I do that?
Old Jul 11, 2011 | 05:03 PM
lucky131969's Avatar
lucky131969
No offense, but if you have to ask that question, you should take your car to a trusted shop for the install.
Old Jul 11, 2011 | 05:08 PM
dheide's Avatar
dheide
None taken...I will but since I am in hawaii and there are not any fantastic shops here so im trying to buy all the stuff and get it put in when I get back to the main land...so back to the topic...should I buy that cam?
Old Jul 11, 2011 | 05:23 PM
vettenuts's Avatar
vettenuts
My personal opinion: Cam is too big for the street, car will run like A$$.
There are a lot of proven cams. Not sure what you are looking for but that cam will likely be too tight on PTV (well below minimums) and with no power until 4,500 RPM or so, below that is will likely suck. Have you run the overlap numbers, etc?
Old Jul 11, 2011 | 07:29 PM
ZZ06's Avatar
ZZ06
There are a lot of proven cams. Not tre what you are looking for but that cam will likely be too tight on PTV (well below minimums) and with no power until 4,500 RPM or so, below that is will likely suck. Have you run the overlap numbers, etc?
mmmm i agree but people run the MS4 on the street and obviously depending how WELL it is tuned, they run fine.
Old Jul 11, 2011 | 07:41 PM
zeevette's Avatar
zeevette
That depends on your definition of "fine". With everything else stock, that cam will require at least 3.73 gears to make it marginally livable, IMO. I assume you have a 6-spd? If you want to make more usable power, then get a cam that's about 228 or so duration, preferably a 224-228 @ 112 so you can have a nice lope, which I figure is something important to you. And keep the lift under .600, unless you plan on doing much more extensive mods.
Old Jul 11, 2011 | 08:22 PM
vettenuts's Avatar
vettenuts
MS4 has less duration and it doesn't meet PTV minimums, you you better plan on flycutting.
Old Jul 12, 2011 | 05:38 PM
dheide's Avatar
dheide
Thanks for the help guys! I decided to go with 232/236 .579/.579 based on what ya'll said...Love the forum!
Old Jul 12, 2011 | 06:15 PM
zeevette's Avatar
zeevette
Which LSA did you decide on?
Old Jul 12, 2011 | 10:01 PM
ZZ06's Avatar
ZZ06
i dont have the MS4 bc its just too much cam as most of you all stated. Wether it can be tuned or not, i just dont believe it is a really good street cam. I have the 233/239 on a 113 and yes i am a 6spd
Old Jul 12, 2011 | 10:04 PM
ZZ06's Avatar
ZZ06
You sure??? I know a few guys cars my mechanic has installed the MS4 and flycutting wasnt needed. ITS CLOSE but it makes the cut. An 03ZO6 he tuned laid down 440/380. (wasnt surprised on the tq side) That being said he wont feel jack in his rpm band until almost 4k rpms
Old Jul 13, 2011 | 04:24 PM
dheide's Avatar
dheide
Im not sure I bought the cam from another forum member...I will ask
To CAM question...need help
