Differential lube confustion
Old Jul 17, 2011 | 09:02 AM
Buggyman's Avatar
Buggyman
Default Differential lube confustion
My o2 has a leaky butt and over the years has lost about 10 oz of oil. I topped it off with some Castrol brand. It was the basic rear end oil of the proper weight. As a result of adding that much have I screwed up the necessary mix of oil and additive to the degree that I may hurt something? Secondly there are numerous posts on what people use some saying include additive others say don't. Some say it is in some of the oil and enough while others are saying there is not enough in it and to add more.
Question.... is the mix I have now ok for the time being and not hurt anything? Secondly, if I change the fluid... is there any real agreement on what to replace it with?
Old Jul 17, 2011 | 09:28 AM
vettenuts's Avatar
vettenuts
Take the car to a parking lot and do some slow figure 8's. If it needs additive, the clutches will chatter. Adding too much additive will effectively eliminate the limited slip capability of the clutches so don't add more than required.
Some of the aftermarket oils do have the limited slip additive in it as it comes from the bottle. Redline 75W-90 has it, Redline 75W-90NS does not. So the answer to this question is very specific to the oil being used.
Old Jul 17, 2011 | 10:06 AM
billla's Avatar
billla
St. Jude Donor '14
Why not just change it at this point and be done with it?
Use the fluid spec'd in the service manual: SAE 75W-90 either with 4 ounces of limited-slip additive OR buy the gear oil with the limited slip additive already in there; for example, Mobile 1 is labeled SAE 75W-90 LS
As for brands, the debate will always rage, but any quality gearl lube will do...
Old Jul 17, 2011 | 02:01 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree 100% best advice---
Old Jul 17, 2011 | 03:35 PM
Choose1's Avatar
Choose1
Anyone here use the Royal Purple gear oil? Does it have the required additive included?
Old Jul 20, 2011 | 07:14 PM
dossdrop's Avatar
dossdrop
I agree. Just go ahead and change it.... I run mobil 1 full synthetic 75w-90 with 1 bottle of GM limited slip/friction modifier additive. I think it's around 4oz. I wouldn't trust just any limited slip additive. These differentials are very picky.... Haha. Just my 2 cents.
Old Jul 20, 2011 | 07:23 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
your GM dealer now has it with the additive mixed in...that would be a great choice for your car now....but you should start from scratch with a full fill.
Old Jul 20, 2011 | 08:51 PM
lucky131969's Avatar
lucky131969
No..and why does there need to be..to make you fell better?
Your owners manual actually has a purpose. Use the recommended fluids...and call it a day.....
To Differential lube confustion
