HVAC problem
Old Jul 17, 2011 | 10:21 AM
maroman88's Avatar
maroman88
Default HVAC problem
my driver side is blowing warmer air then the passenger side when the AC is on! i read thru a bunch of threads already, i did the reset thru the DIC, i pulled the fuses to reset, i tore apart the car and removed the acuator and did the adjustment to that. i have NO codes for the HVAC system. i climbed under the dash and watch the acuator move and its moving... what else?!
Old Jul 17, 2011 | 10:49 AM
rebelheart's Avatar
rebelheart
Once again,your system is most likely a bit low on freon! This is the most common cause for this condition.
Old Jul 17, 2011 | 10:55 AM
maroman88's Avatar
maroman88
i obviously checked that... and the passenger side is ICE cold
forgot to mention it is the dual zone HVAC, i hate overly complicated things
Old Jul 17, 2011 | 11:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHAT CODES are you seeing when its hosed up?
BC
Old Jul 17, 2011 | 11:09 AM
rebelheart's Avatar
rebelheart
Best check that freon level again,many ppl have torn their dashes apart chasing ghosts,only to add a bit of freon after the fact and cure the problem.The passenger side will be "ice" cold even if the system is a bit low.
Old Jul 17, 2011 | 04:07 PM
maroman88's Avatar
maroman88
no codes, had no history codes under the HVAC previously, i already tried adding some freon, at first i thought it was just low and added some, then i noticed the passenger side was still blowing cold
Old Jul 17, 2011 | 04:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the drivers side under dash close out panel.. Get an inspection mirror and flashlight. Observe the controller and have someone cycle the temp control **** thru it full temp range and see if the controller consistently moves thru its full range"
There should be range marks on the controller
BC
Old Jul 17, 2011 | 05:45 PM
maroman88's Avatar
maroman88
assuming its those marks in the last picture?
if so then it goes way past on the cold side, the hot side is right on target
Old Jul 17, 2011 | 06:24 PM
dmarkshark's Avatar
dmarkshark
You said you adjusted the actuator, could you have messed that up somehow? That would explain why it would not set correctly? Just some thoughts.
Old Jul 17, 2011 | 06:25 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you had the controller open, was the main drive gear cracked??
Old Jul 17, 2011 | 07:16 PM
maroman88's Avatar
maroman88
nope not cracked, when i had it apart i marked everything off like in the right up in another thread. its not like it worked before i took it apart... im stumped.
i checked my freon pressure again... just about 32lbs of pressure when AC on highest
Old Jul 17, 2011 | 07:43 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,, thats too high but modt likely not your issue.
Take the actuator off and manually position the shaft to the coldest position and see if its cold out that vent.
BC
Old Jul 17, 2011 | 10:16 PM
dmarkshark's Avatar
dmarkshark
Im curious, did it ever work correctly for you while you have owned this car? Or, is this something that just started.
Old Jul 17, 2011 | 11:50 PM
maroman88's Avatar
maroman88
ill try manually adjusting it.
yea im positive it worked last summer, its a very noticable differance to the point where it doesnt cool the driver side
Old Jul 18, 2011 | 12:15 AM
LT1driver's Avatar
LT1driver
would this also be the problem for a car that: when adjusting temp up to say 68 and then trying to go back to 60 temp won't go back down and air blows at higher temps
Old Jul 19, 2011 | 07:27 AM
Lowcash's Avatar
Lowcash
BC
Bill,
Looking at your 2nd picture, is that the position for the coldest setting (to the right of center) ?
Old Jul 19, 2011 | 11:52 AM
maroman88's Avatar
maroman88
k removed it and adjusted by hand, no real differance, reinstalled it and its deffinatly going all the way to the coldest position. guess that rules out the acuator, the flap seems to open n close without any obstruction as well
To HVAC problem
Old Jul 20, 2011 | 11:15 AM
maroman88's Avatar
maroman88
B0363H did pop up today
Old Jul 20, 2011 | 02:07 PM
dmarkshark's Avatar
dmarkshark
Back to the freon? How are you checking it? I had this issue and when all said and done, it was a plugged orifice tube.
Old Jul 21, 2011 | 11:57 PM
maroman88's Avatar
maroman88
where is said orfice tube? i have a guage that goes on the i believe low side port, where u would add more freon from
