Suddenly turn signals don't work
Old Jul 24, 2011 | 09:35 AM
minitech's Avatar
minitech
Default Suddenly turn signals don't work
Is this a fuse problem? Did some searching didn't find the answer.
Old Jul 24, 2011 | 09:49 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Most likely the hazard flasher switch. Try pushing it in and out a few times and see if the flasher starts working again. If it does, it’s time to replace it. It is a known issue.
Old Jul 24, 2011 | 10:05 AM
Loudlowfastc5's Avatar
Loudlowfastc5
Cruising
Same problem here
Old Jul 24, 2011 | 10:13 AM
Eric D's Avatar
Eric D
Here is a link that tells everything you need to know about it ----> Hazard Flasher
Old Jul 24, 2011 | 11:35 AM
m6 c5's Avatar
m6 c5
Yep mine does it intermittently I just hit the hazard switch a bunch of times and usually have to turn my blinkers on with the hazards on for them to start working again but then it will go several months. Wrks for me until I get around to fixing the problem.
Old Jul 24, 2011 | 12:36 PM
n8dogg's Avatar
n8dogg
Hazard switch is likely the problem. Try smacking it a few times. You can get away with replacing it by removing the radio and the screws on top of the IPC.
Old Jul 24, 2011 | 01:47 PM
Baldfart's Avatar
Baldfart
On mine, when the turn signals quit I just could wiggle the hazard switch without turning them on and my turn signals will start working.
Old Jul 24, 2011 | 04:51 PM
minitech's Avatar
minitech
Working the hazard switch didn't do anything. Which fuse is it?
Old Jul 24, 2011 | 04:56 PM
m6 c5's Avatar
m6 c5
Try turning your hazards on and then turning one of your blinkers on and then cutting your hazards off to see if it will work like that.
Old Jul 24, 2011 | 04:59 PM
m6 c5's Avatar
m6 c5
Oh and the hazards and turn signals are on the same fuse, its # 15 in the passenger side foot well fuse box.
Old Jul 24, 2011 | 06:49 PM
lespaulr0cker's Avatar
lespaulr0cker
The Hazard switch is more than likely the problem if you have been running the A/C hard, condensation from the cold vent is what causes them to act up.
Old Jul 24, 2011 | 07:59 PM
m6 c5's Avatar
m6 c5
That is probably what caused mine to act up again because its been in the upper 90's to low 100's here for over a week and I had not really used the ac until now. And it acted up just a couple days ago which was right in the middle of this heat wave, hopefully these storms will cool if off some.
To Suddenly turn signals don't work
