Stranded by Column Lock
Old Jul 26, 2011 | 07:35 PM
c4_4ya's Avatar
c4_4ya
Default Stranded by Column Lock
Of course this happens after all the service departments are closed tonight...and while out of town.
Anyone got recommendations on a tow and fix for this around the Durham, NC area? Don't know much about the GM service departments in this area...
Old Jul 26, 2011 | 08:05 PM
c4_4ya's Avatar
c4_4ya
Originally Posted by 8VETTE7
Get your self a very large tube of K Y Lube. Your going to need it if you have a Stealer fix it...
No doubt... At least it should be fixed under the recall. But you know how they always manage to "find" (read:plant) problems you weren't having lol
Old Jul 26, 2011 | 08:40 PM
ICUALL's Avatar
ICUALL
What exactly is the issue you are having, is it locked, giving you a message & or shutting off fuel ?
Old Jul 26, 2011 | 08:59 PM
c4_4ya's Avatar
c4_4ya
It's locked. Also gives the 10 sec message then finally service column lock. Tried removing and replacing fuse 25 and bumping the wheel no change. Didnt try to test fuel cutoff as I'm in a hotel parking lot.
Old Jul 26, 2011 | 09:15 PM
ICUALL's Avatar
ICUALL
Need to give the steering wheel a few good forceful slams to the right and left and then put the key back in and try it... You really can't break the wheel so do not be afraid of the forceful
Old Jul 26, 2011 | 09:35 PM
c4_4ya's Avatar
c4_4ya
Well fornicate me... It worked lol. I tried that several times but got nuts on it and voila! IC I owe you a round! The only reason it worked is because I just got a rental car
Will that always work (I plan to take it in for the recall)?
Old Jul 26, 2011 | 10:15 PM
ICUALL's Avatar
ICUALL
I would not advise the recall as they fail, you need to invest in a column lock bypass from Corvettes of Houston. I put one in my 2000 and have never had a issue in 10+ years.
It works to jerk the wheel in almost all cases, the problem is most owners are afraid to be rough with their baby. What you are trying to do is release a metal pin from a metal frame, it's only "going Nuts" on it that is sufficient. Glad it unlocked now call Corvettes of Houston or visit the website to get the fix GM doesn't want you to know about...
Oh the presence of the Rental Car propably put you over the top....
Old Jul 26, 2011 | 11:37 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I would not advise the recall as they fail, you need to invest in a column lock bypass from Corvettes of Houston. It works to jerk the wheel in almost all cases, the problem is most owners are afraid to be rough with their baby. What you are trying to do is release a metal pin from a metal frame, now call Corvettes of Houston or visit the website to get the fix GM doesn't want you to know about.
Most likely cause of your poblem is a weak or bad battery or loose or corroded battery cables. The majority of the column lock symptoms are the result of the battery.
Here are some helpful links....
How to install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get a CLB Kit from either of these vendors:
http://www.corvettesofhouston.com/pr...e9bf70207aef69
http://www.thunderracing.com/catalog...d=220&pcid=156
Steering Column Lock FAQ's:
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Jul 27, 2011 | 01:59 PM
craig04c5's Avatar
craig04c5
Yep, get that column lock bypass in there before it locks up again.
Old Jul 27, 2011 | 02:45 PM
hotwheels57's Avatar
hotwheels57
If your car has already a GM fix (there was more than one GM variation) done, you'll probably need to remove the GM fix before the column lock bypass can be successfully installed.
I have a late production '04 Commemorative Edition Z06. I had read here and elsewhere that the battery is more often than not the cause of the column locking up. Since I maintain my battery on a BATTERY TENDER PLUS, I've never had the experience that you have. And since '06, I chose not to install a column lock bypass device. From the GM service history report, I was certain no GM fix had ever been done.
Last month I decided to go ahead and install the device from CORVETTES OF HOUSTON. Read the instructions thoroughly and take your time. The hardest part (for me) was not removing the panels, but gaining access to the connectors. It's a test in patience to reach up into that confined space to release the connector. Between the instructions that come with the device and what I learned from this http://www.ls1howto.com/index.php?article=24 it was done in a couple of hours.
Old Jul 28, 2011 | 04:36 PM
c4_4ya's Avatar
c4_4ya
Thanks to all for the advice and input, I will definitely be installing the CLB kit once I'm home again!
Old Jul 28, 2011 | 05:56 PM
ssdungeon's Avatar
ssdungeon
Its probably in those column lock bypass instructions but if you hook 12 volts momentarily..... I said MOMENTARILY to the two wires on the silenoid under the dash I think its a orange and black wire. Disconnect the harness and apply 12v for a second youll hear it click and the column will unlock and you can go about your business then get the recall done or get the bypass.
I was in that boat with no paddle a few months ago.
To Stranded by Column Lock
