Will the ZR1's equipment work?
Also to add....
Horsepower TV did a hi mileage C5 with bosch 4 plugs. It dunked 11hp higher.
My friend with a 2001 Z06 bought the MSD coil packs and didnt notice a difference,or at least enough to justify it's price.
A new set of NGKs later-he was right.
After owning so many cars, I come to find out this was an issue in many cars I procured. All of the missing cars had Bosch plugs in them. Amazing but true.
It also was the first thing I put in my vette when I got it,that and dynatech LT's ...20k miles so far,not one problem. Knock on wood.
Bill
Its surrounded by a ceramic insulator. The metal tip is just about FLUSH in the insulator. Over time,, that metal platinum/palladium electrode will erode down BELOW the ceramic tip and cause all sorts of issues. Under severe use,,, it doesn’t take long for it to wear down!
I took a BOSCH plug apart once to get the platinum/palladium center electrode out of the plug. Wanted to see how valuable it was.
Well,,,,,,,,,,,,,,,,,,,,, those bastards are NOT stupid!
The platinum/palladium precious alloy is a very very very small tip section fused to a metal electrode core conductor.
SO,, not much of the plug is PLATIMUM!
Truse me!ANY new plug will make your car run and idle better when you initially install the new ones /change out the old ones!. They don’t have to be $25 each for the engine to run much better!
Been there and done that! Wasted the money! At least it was only in a 4 cyl turbo Volvo and they were only single electrode BOSCH plugs. Glad I Didn’t waste an arm and a leg on the more expensive ones!
They worked good for a while. A lot shorter than they were advertised to last!You do know that any spark that you install in the engine will ONLY FIRE FROM ONE SINGLE ELECTRODE POINT and NOT all the multiple other electrodes!!!
IMHO< multiple electrodes are SNAKE OIL!The ONLY reason to run ANY of the fancy metal plugs is Sparkplug LONGAVITY!
If you run a standard copper core AC Delco or NGK TR55's, with NOS TR6's, Denso IT20's they actual work better BUT,, will NOT last as long as a iridium plug.
Platinum/palladium electrode/cathodes are just for the 100K mile service life and add NOTHING to HP/Tq increases!.
BC
Not worth it.....considering you'll have to upgrade the transmission, differential, etc.
