c5 throwing codes abs/traction control ect.
Old Jul 31, 2011 | 07:17 PM
flynlow32's Avatar
flynlow32
Default c5 throwing codes abs/traction control ect.
Im selling my car and started it up the other day to move it from my two car garage ten miles away from home to home so i could get it ready for anyone buying it. On the trip, i threw several codes. Can anyone help me break the code down and explain what may need to be done so i can have these issues fixed?
10 pcm po137 HC
28 tcs c1226 c
28 tcs c1286 c
28 tcs c1295 C
Bo-Rfa U1096 H
Bo-Rfa U1064 H
Bo-Rfa U 1016 H
Bo-Rfa c2120 HC
Thanks for any help. Please point me in the right direction.
Jeff
Old Aug 1, 2011 | 09:04 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Try the easy fixes first. Loose connections, check all ground wires, remove all the wheels and check for cut wires. I had that happen on my 01 SS Camaro and it turned out to be a cut wire going to the ABS sensor on the front right wheel.
Old Aug 1, 2011 | 09:15 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
C1226 LF Excessive Wheel Speed Variation
C1286 Steering Sensor Bias Malfunction
C1295 Brake Lamp Switch Circuit Open
C2120 TPM System Malfunction (No Sensors Received)
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Old Aug 1, 2011 | 02:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You my friend most likely have an issues with one or BOTh of the door wiring harness connectors inside the door accordion tube.
All those tell me you have a serial data issue.
BC
To c5 throwing codes abs/traction control ect.
