Starting Procedure for 6 Speed
Old Aug 4, 2011 | 11:59 AM
gtragitt's Avatar
gtragitt
Cruise-In II Veteran
Cruise-In III Veteran
St. Jude Contributor
I will look on my receipt and try to get the specific relay information.
I think parking in reverse has no impact on my battery.
The thread title was formulated on initial mis-information from the dealer stating I should start the car in reverse. The next day the dealer indicated I should park the car in reverse as stated in the Owners Manual instead of starting the car in reverse.
Although the dealer indicated the audio converter is not draining the battery, I think it was a good suggestion to connect its power to the ignition switch.
I think it is fantastic that people on this forum are so helpful.
Old Aug 4, 2011 | 12:07 PM
lucky131969's Avatar
lucky131969
I could not disagree more.
Old Aug 4, 2011 | 01:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
GM10-Aux Audio Adapter.
There was a bunch of these that were wired incorretly or incorrectly for C5 useage. Look in the AUDIO Forum and you should be able to find the post. I will try to find the post on how to rewire it so it isnt on all the time.
If it were me,,,,,,, I would
That STEALERSHIP sounds like there real winners!
When something is "SHORTED" think of blown fuses, smoke, melted wires, flames or no signal.
Did they conduct a battery current draw test of the electrical system. If the answer is I DONT KNOW or NO,, your issue is NOT resolved and will still give you issues.
Youe car is designed to sit idle for in EXCESS of 30 days and should still be able to crank and start the engine. PERIOD!!
C5's DO NOT need to be left in reverse to prevent any battery drain issues That service writer is NUTS!
Old Aug 4, 2011 | 05:06 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Ipod adapter killed my stock battery. I fixed the Ipod drain issue by hooking it up to a switched 12v. Issue fixed !
My Z06 very often sits 2 weeks at a time. Starts up every time ! I dont use a battery tender either.
I always leave my car in first gear when parked. LIke said above.... I think GM recommends you put it in reverse because of the higher gear ratio... not because of battery drain.
Toque
Old Aug 5, 2011 | 12:07 AM
gtragitt's Avatar
gtragitt
40437 Ignition Relay Coil is Shorted
I have the printout for the battery current draw test:
641 CCA vs 700 rated
12.87 volts
Amp Hours 13.9
Old Aug 5, 2011 | 11:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
12.87 volts
Amp Hours 13.9
The TEST needs to be done on the battery, DISCONNECT the NEG terminal and INSERT a DC AMP meter between the battery and battery cable. The current draw when the car is in the SLEEP/SECURITY Mode MUST be LESS THAN 25 MILLIAMPS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
BC
Old Aug 7, 2011 | 05:30 PM
gtragitt's Avatar
gtragitt
Bill,
Thanks for taking all the time to post to my thread. You have been a huge help. I bought a multimeter and checked the current. It was 3.66 mAmps.
Greg
Old Aug 7, 2011 | 05:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill,
Greg
Well,, its not outragiousely high but a little higher than normal.
Do you have any lights that remain on or any aftermarket stuff istalled with a menmory??
Old Aug 8, 2011 | 11:46 AM
gtragitt's Avatar
gtragitt
No I removed the lamp from the underhood light during the test.
Old Aug 8, 2011 | 03:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are other lights in the car that can stay on. Check it out in the dark and se if anything is lighted that shouldnt be.
Old Aug 8, 2011 | 04:36 PM
chaase's Avatar
chaase
St. Jude Donor '12
Check the map lights, at least in a vert we have a little button on the mirror which turns on a small light that you can barely see.
Old Aug 8, 2011 | 04:52 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
I had the same problem and it was the GM10-Aux Audio Adapter.
It is always powered on. If you do a search there is a simple fix that a forum member did and took photos. I did it and it fixed the problem. The fix is to change the wire that is hot all the time to a hot only when the ignition is on.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Aug 10, 2011 | 10:38 PM
  #33
gtragitt's Avatar
gtragitt
I did a search and din't find it. I am sure it is there and I overlooked it. I like your idea.
Old Aug 11, 2011 | 04:13 PM
  #34
SacCityCorvette
Supporting Vendor
Here is the link!
Also I have the PXHGM4 iPod Adapter already modified that I am going to sell since I dont need it with my new stereo if your inerested.
http://forums.corvetteforum.com/c5-g...changer-5.html
