Oil "spoiling"??
Old Aug 1, 2011 | 10:48 PM
cruisemon's Avatar
cruisemon
Default Oil "spoiling"??
Four or five years ago I found a killer deal on Mobil 1 and bought eight cases. I had drained the engine the other day and when I opened a bottle of the oil it had "lumps" in it. I opened another bottle and it had lumps as well. The lumps were whitish tan and the more liquid darker brown part.
Has anyone else ever had this happen? I was concerned enough that I went and bought fresh oil. Any chance that all I needed to do was shake it up and remix it? I really don't think that would be a solution but I still have two cases that I'm going to have to dump.
Charlie
Old Aug 1, 2011 | 11:40 PM
jrose7004's Avatar
jrose7004
I'd sure try shaking it up and see what it does to the lumps.
Old Aug 2, 2011 | 09:24 AM
av8or's Avatar
av8or
Did you check the Exxon/Mobil (or Mobil 1) website? Might already be a FAQ on this subject. Or, you could post that question yourself. Might be worth a little effort before dumping two cases of unopened oil.
Old Aug 2, 2011 | 10:15 AM
billla's Avatar
billla
St. Jude Donor '14
I'd be more worried that the "killer" deal was something funky about that batch. I can't think of anything that would preciptiate out.
Why take a chance?
ricknyc23's Avatar
ricknyc23
Old Aug 2, 2011 | 06:24 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Charlie
Was that the "killer deal" that Pep Boys ran? If so, I still have some Mobil 1 from that deal also.....
Old Aug 2, 2011 | 07:04 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Charlie
There are a number of bacteria that will grow in petroleum. It is a REAL issue with Jet fuels. It looks like snot! In my younger days I had the fine job of cleaning an aircraft fuel tanks that had sat for about three months and was taken over by the bacteria. I expect that this is what happened to your oil as well. I wouldn't use it!
Old Aug 2, 2011 | 07:13 PM
baxsom's Avatar
baxsom
send a sample of it to blackstone labs and have them test the oil. see what is inside of it.
Old Aug 2, 2011 | 08:44 PM
SimpleTom's Avatar
SimpleTom
You might have purchased counterfeight (sp?) product?
Old Aug 2, 2011 | 10:13 PM
had2have-it's Avatar
had2have-it
I've stored motorcycle oil for years and never had it come down with the "lumps". If it did I wouldn't use it.
Old Aug 2, 2011 | 10:47 PM
cruisemon's Avatar
cruisemon
This may be what happened. Didn't want to describe the "lumps" quite so graphically but since the word came up, it looked like someone had coughed a loogie or four in the bottle.
Charlie
Old Aug 2, 2011 | 10:48 PM
cruisemon's Avatar
cruisemon
It was indeed from Pep Boys.
Charlie
Old Aug 3, 2011 | 10:18 AM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I purchased about 4 of the 5qt containers of the Mobil 1 about 3 years ago and used one last week and it looked fine. I like that the large containers have the vacuum seal at the top, I could not remember if the quarts had the same seal?
To Oil "spoiling"??
