No dash lights
Old Aug 8, 2011 | 04:41 PM
Mrgogo's Avatar
Mrgogo
Default No dash lights
I tried a search but couldn't find anything that matches my problem. Here goes.
When i put the key in I get proper dash lighting. But when the engine engages they go off. When I remove the key the lighting appears and shuts off normally. The HUD works normally and I get a radio staion frequency display along with temp. All the instruments work normally. Speedo, tach, temp, etc. The headlights come on with the engine running. The headlights will pop up but no lights with with the engine off. When the engine is on the lights work normally. Strange. My guess is there is something wrong in the MFS. I'm hoping someone here can help me diagnose the problem. Lots of very knowledgeable people here. Thanks!
Old Aug 8, 2011 | 05:36 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Iam by no means an authority here on this one but have you checked the "twilight sentinel" option just for ha ha's...possibly it is confused? Try turning it off? Just a thought. It is located in the options section on the DIC...toggle through it....you'll find it.
Old Aug 8, 2011 | 05:59 PM
black98c5's Avatar
black98c5
Not an electrical guru here either, but I've had similar issues, along with a few others, that were solved when I had the ignition switch replaced. Just something to consider looking into. I'm sure Bill C. will chime in!
Old Aug 8, 2011 | 06:02 PM
lucky131969's Avatar
lucky131969
Have you checked the dimmer to see if it's turned down?
Old Aug 8, 2011 | 09:09 PM
65GGvert's Avatar
65GGvert
Sounds like the problem with your dash lights.
Old Aug 8, 2011 | 11:16 PM
Mrgogo's Avatar
Mrgogo
Yes I fiddled with the dimmer switch. Turned it both ways pushed it in and out a few times too. Boy that sounds nasty don't it? I'll check the twilight function too.
Old Aug 9, 2011 | 07:02 AM
lucky131969
ahhhh....it doesn't move in and out....
Old Aug 9, 2011 | 09:47 AM
Mrgogo's Avatar
Mrgogo
Lucky, I hope you remember me. You helped me sort out a hazard light problem. I hope you can help with this one as well. Heres the problem. No dash lights while the engine is running. No tail lamps while the engine is running. When I walk up to the car I use the fob to unlock the doors I can see the dash lights on. Put the key in and turn the engine on the lights go out. I found out last night that I also have no tail lamps lit. Brake and flashers OK. Just for giggles and grins I changed the settings on the twilight sentinel like Xtremevette suggested and poof they now work! WTF!? I should be able to maually turn lights on and off by using the MFS like I usually do. Thats why I suspect the MFS may be bad. Since I'm not the electrical guru can you help with a logical step by step elimination process? Oh yeah, my dimmer switch has a push to set feature for intensity. Thanks in advance Lucky!
Old Aug 9, 2011 | 09:54 AM
lucky131969
Ok. The twilight sentinel bypasses the MFS for exterior lighting.....sooo....you should have had no tail lights, front park, or marker lights at all............
Old Aug 9, 2011 | 04:58 PM
Mrgogo's Avatar
Mrgogo
Lucky when I get home this eve I'm gonna do a through check on my lighting. I wanna be able to tell you what is absolutely correct. I'm gonna check the owners manual as well for operation of the sentinel. Something is definately not correct. Thanks again for your time.
Old Aug 9, 2011 | 05:03 PM
lucky131969
Don't misunderstand me, the suggestion to try the twilight sentinel was spot on.......it's a great troubleshooting tool. You just have to verify exactly what works with/without twilight sentinel.
To No dash lights
